Hi…I perform the standard melt quench technique for obtaining amorphous silica. But for some reason I see the flying ice cube effect right after my first equilibration step at 300K. I have tried reducing the timestep, modifying the initial structure but I still get the same flying ice cube effect. I don’t understand where I am going wrong.
Any help is much appreciated. Thanks in advance.
This is my code
# ---------------INITIALIZATION------------------------------
atom_style charge
# ---------------STRUCTURE DEFINITION------------------------
lattice custom 5.067922 a1 1.000000 0.000000 0.000000 a2 0.000000 1.000000 0.000000 a3 0.000000 0.000000 1.393663 &
basis 0.000000 0.500000 0.250000 basis 0.000000 0.000000 0.000000 basis 0.500000 0.000000 0.750000 basis 0.500000 0.500000 0.500000 &
basis 0.250000 0.412034 0.375000 basis 0.087966 0.750000 0.125000 basis 0.750000 0.587966 0.375000 basis 0.912034 0.250000 0.125000 &
basis 0.750000 0.912034 0.875000 basis 0.587966 0.250000 0.625000 basis 0.250000 0.087966 0.875000 basis 0.412034 0.750000 0.625000
region simbox block 0.0 7.0 0.0 7.0 0.0 7.0
create_box 2 simbox
create_atoms 1 box basis 1 1 basis 2 1 basis 3 1 basis 4 1 &
basis 5 2 basis 6 2 basis 7 2 basis 8 2 &
basis 9 2 basis 10 2 basis 11 2 basis 12 2
mass 1 28.0855
mass 2 15.9994
group siliconatoms type 1
group oxygenatoms type 2
set group siliconatoms charge 2.4
set group oxygenatoms charge -1.2
# ---------------TEMPERATURE AND TIMESTEP--------------------
velocity all create 300.0 12345 dist gaussian
timestep 0.002
thermo 10000
thermo_style custom step etotal pe ke temp density vol lx ly lz
# ---------------INTERATOMIC POTENTIAL-----------------------
pair_style comb
pair_coeff * * ffield.comb Si O
neighbor 2.0 bin
neigh_modify every 10 delay 0 check yes
fix charge all qeq/comb 100 0.05 file qeq.comb
# ---------------EQUILIBRATION-------------------------
dump equib all atom 10000 equib.atom
fix equilibration all nvt temp 300.0 300.0 $(100.0*dt)
run 100000
unfix equilibration
minimize 0.0 0.0 100000 100000
undump equib
# ---------------MELTING-------------------------------------
dump melt all atom 10000 melt.atom
fix melting1 all nvt temp 300.0 1000.0 $(100.0*dt)
run 87500
unfix melting1
fix melting2 all nvt temp 1000.0 2000.0 $(100.0*dt)
run 125000
unfix melting2
fix melting3 all nvt temp 2000.0 3000.0 $(100.0*dt)
run 125000
unfix melting3
fix equilibration all nvt temp 3000.0 3000.0 $(100.0*dt)
run 100000
unfix equilibration
undump melt
# ---------------QUENCHING-----------------------------------
dump quench all atom 10000 quench.atom
fix quenching4 all nvt temp 3000.0 2000.0 $(100.0*dt)
run 500000
unfix quenching4
fix quenching5 all nvt temp 2000.0 1000.0 $(100.0*dt)
run 500000
unfix quenching5
fix quenching6 all nvt temp 1000.0 300.0 $(100.0*dt)
run 350000
unfix quenching6
run 100000
unfix equilibration
undump quench
write_data final_amorphous_bulk_SiO2.dat
write_restart final_amorphous_bulk_SiO2.restart
