myworld
November 9, 2021, 4:05am
#1
Dear. Julian
In the keywords, i’d like to get groupvelocity
So I include groupvelocity keyword in input.
But, I could not find the info about groupvelocity at the calculation output.
Where could i find the infor about groupvelocity in the output?
or Could I get the groupvelocity concurrently with calculation of thermal conductivity?
julian
November 9, 2021, 4:52am
#2
The output for the group velocities should be after the frequencies for each
k point in the GULP output:
K point 10 = 0.062500 0.187500 0.187500 Weight = 0.004
Frequencies (cm-1) :
35.48 36.40 55.11 65.00 65.35 69.57 76.47 80.02 81.49
90.39 92.30 105.13 108.42 117.60 120.22 121.90 126.78 129.64
131.65 136.17 140.87 142.78 146.15 150.66 153.42 156.77 161.99
162.30 168.54 174.83 185.29 191.95 196.24 196.84 210.00 217.95
522.69 523.77 527.95 534.62 548.82 550.07 552.20 555.57 560.18
563.76 567.80 568.72 571.30 576.21 579.03 579.69 611.04 611.96
616.38 618.67 623.27 631.00 635.63 645.70 856.06 857.68 864.77
866.60 869.39 870.27 878.00 883.53 896.97 903.78 917.22 920.06
Group velocities (cm-1.Ang) :
Mode X Y Z
1 10.143314 89.060616 90.753465
2 29.048987 87.030304 96.541942
3 22.785549 117.812017 75.555719
4 -6.002210 83.839838 23.017065
5 10.194852 17.701837 -19.132623
6 4.171938 17.434621 30.391648
7 14.302651 59.521725 8.909531
8 1.668237 59.952394 -17.005749
9 -14.394475 22.969855 -13.108723
10 -22.593768 44.701118 -30.223168
11 19.527123 14.810086 -36.115895
12 7.481936 34.740610 -36.160432
This is just a quick partial grab from an output to show you what should
appear. I’d recommend running separately from the thermal conductivity
calculation where you are trying to get the third order force constants.
It’s cheap in comparison to thermal conductivity and so it’s not a big overhead
to run it as a separate calculation.
myworld
November 9, 2021, 8:13pm
#3
Dear. Julian
Thanks so much for your reply.
I confirmed the group velocity thanks to your comment
I’d better to calculate this value separately like your comment. It is a good tip to me. thanks.
And Group velocities (cm-1.Ang) look like that the unit phase/cm or phase/Angstrom? or cm/s?
also, to get Group velocity near gamma point , almost limit to gamma point (kpoints 0 0 0) ,
Is the below input setting reasonable?
kpoints
0.001 0.001 0.001
Sincerely,
julian
November 9, 2021, 11:38pm
#4
The group velocities are in cm-1/Ang as they are the frequency (cm-1) derivatives with respect to reciprocal space (Ang-1).
I haven’t tested, but a value of 0.001 should be pretty close to gamma. It’s always best to run a series of points to see how to extrapolate the trend to the limit.
myworld
November 10, 2021, 11:21pm
#5
Dear. Julian
I appreciate your reply
as your comment, 0.001 fine to me
Best regard.
myworld
February 15, 2022, 10:18pm
#6
Dear Julian
in the group velocity
Mode X Y Z
Are 10.143314 , 89.060616 and 90.753465 the velocity of each directions of x,y,z respectively?
julian
February 16, 2022, 12:15am
#7
The units are output as “Group velocities (cm-1.Ang)” and so that would be a reasonable conclusion.
