For help!
Hi, I want to compare the results with that of DFT
And I have obtained the coordination from DFT,
the lattice vector is
a1 2.78340565 1.60700000 0.00000000
a2 -2.78340565 1.60700000 0.00000000
a3 0.00000000 0.00000000 20.98703432
When I write data file, I find that the lattice vector is perpendicular to each other, can I do some modification in input files to make the configuration is periodic along a1, a2 and a3 direction, which a1 and a2 are not perpendicular to each other.
Many Thanks
Xiaojing
If you want to use a non-orthogonal simulation box, then
LAMMPS calls that a triclinic box. See section 4.12 of
the manual for details.
