Hi my friends!
I am trying to simulate an alloy with base Cu and different percent of Al. When Cu is %100 & Al is %0, how can I use AlCu.eam.alloy for force field ?
I use this commands:
set group all type/fraction 2 0 12393
mass 1 63.546
mass 2 26.9815
Is it true?
Nili
Hi my friends!
mass 1 63.546
mass 2 26.9815
Is it true?
please think about it. you should come up with the answer by yourself.
think about what your "set" command line is doing (or not).
please also consider, that it is *extremely* simple in this case to
verify whether you get the desired result.
Hi Dr.Axel ;
I forgot to write it :
pair_style eam/alloy
pair_coeff * * AlCu.eam.alloy Cu Al
I want to know is it true?
I thought a lot and run more time but I am in doubt yet…
So Thanks;
Nili
