Hi all,
Can someone give me an example of extracting fourth-order force constants using hiPhive? Thanks!
Hi all,
In the hiphive tutorial a 4th order FCP is constructed for FCC Ni. This is probably a good starting point.
Hi Erik,
Thanks for replying!
Did you mean this example? Molecular dynamics simulations — hiPhive documentation
I actually want to compute lattice thermal conductivity using fourth-order force constants. I need to write fourth-order force constants as what hiPhive did for third-order force constants. Then I can compute kappa using ShengBTE - FourPhonon. Is this doable?
Maybe, see this MR
Thanks!
Is it available in the released version? I didn’t find this part in hiPhive-1.1
No, it is still a merge request. You can checkout the branch and try using it. The code looks sound to me, but note that we have also not tested it ourselves.
