hi dr.steve
when I run the fix bottom freeze command I face with this error Invalid fix style . what should I do to solve my problem.
thanks a lot
best
ramin
hi dr.steve
thanks a lot
best
ramin
hi dr.steve
read the manual. it explains what to do.
i also advise to read the fine print of the fix freeze documentation.
it is very likely that this is not the fix that you want to use.
That command is in the granular package, so if you
didn't build with it, you can't use it.
