I am having an issue with recreating the MARTINI model derived by marrink et. al. in LAMMPS. I have been working on this problem for a while, and have an extensive method developed, but I find that when I turn off the momentum control in the final analysis run, everything freezes and drifts. All units are non-dimensional based by the MARTINI water model. I am trying to simulate a Butane only system (atom type 2 here) with 400 sites and periodic boundary conditions. The non-dimensional mass for butane in this system is set to 0.806538. The same drifting and freezing problem happens when using 400 water sites. Please Help.
Here is the code in my in file:
#Lammps infile water, INNER, W,0, O,400, DPC_,0, MOLECULES,1,OILTYPE
#-----------------------STARTING RUN--------------------------#
units lj
atom_style full
lattice fcc 1.0
read_data atoms.txt
group oil molecule 2
pair_style lj/gromacs/coul/gromacs 1.91489 2.55319 0.0 2.55319
pair_coeff 1 1 1.000000 1.0
pair_coeff 1 2 0.360000 1.0
pair_coeff 1 3 1.000000 1.0
pair_coeff 1 4 1.000000 1.0
pair_coeff 1 5 0.680000 1.0
pair_coeff 1 6 1.000000 1.0
pair_coeff 1 7 1.000000 1.0
pair_coeff 2 2 0.680000 1.0
pair_coeff 2 3 0.360000 1.0
pair_coeff 2 4 0.360000 1.0
pair_coeff 2 5 0.520000 1.0
pair_coeff 2 6 0.360000 1.0
pair_coeff 2 7 0.360000 1.0
pair_coeff 3 3 0.680000 1.0
pair_coeff 3 4 0.680000 1.0
pair_coeff 3 5 0.680000 1.0
pair_coeff 3 6 1.000000 1.0
pair_coeff 3 7 1.000000 1.0
pair_coeff 4 4 0.680000 1.0
pair_coeff 4 5 0.840000 1.0
pair_coeff 4 6 1.000000 1.0
pair_coeff 4 7 1.000000 1.0
pair_coeff 5 5 0.840000 1.0
pair_coeff 5 6 0.680000 1.0
pair_coeff 5 7 0.680000 1.0
pair_coeff 6 6 1.000000 1.0
pair_coeff 6 7 1.000000 1.0
pair_coeff 7 7 1.000000 1.0
bond_style harmonic
bond_coeff 1 27.6125 1.0
bond_coeff 2 27.6125 0.787234
angle_style cosine/squared
angle_coeff 1 2.5 180
angle_coeff 2 2.5 120
dielectric 20.0
special_bonds fene
neighbor 0.5 bin
fix 1 all nve
fix 2 all momentum 1 linear 1 1 1 angular
fix 3 all press/berendsen iso 0.001250 0.001250 0.56045 modulus 4.465977
fix 5 oil temp/berendsen 0.498868 0.498868 0.56045
compute oil_temp oil temp
compute vpress all pressure thermo_temp virial
compute kepress all pressure thermo_temp ke
dump 1 all custom 2500 simulation1.movie id mol x y z
thermo 500
thermo_style custom step temp c_oil_temp pe press c_vpress vol
min_style cg
minimize 0.0 1.0e-8 1000 1000
velocity oil create 0.01 5334535 rot yes mom yes
timestep 0.011214
run 25000
##################Hold TEMP/PRESS (Stablize)##########################################
unfix 2
fix 2 all momentum 10 linear 1 1 1 angular
unfix 3
unfix 5
dump 2 all custom 2500 simulation2.movie id mol x y z
thermo 500
timestep 0.011214
run 1000000
##################Hold TEMP/PRESS 160nsec (No Momentum Control)####################################
unfix 2
unfix 3
dump 3 all custom 2500 simulation3.movie id mol x y z
thermo 500
timestep 0.011214
run 1000000
##################Analyze 80nsec #########################################################
dump 4 all custom 12500 run.txt id type x y z vx vy vz
dump 5 all custom 2500 simulation4.movie id mol x y z
compute msd_total all msd com yes
compute msd_oil oil msd com yes
thermo 1000
thermo_style custom step temp c_oil_temp c_msd_total[1] c_msd_total[2] c_msd_total[3] c_msd_total[4] c_msd_oil[1] c_msd_oil[2] c_msd_oil[3] c_msd_oil[4] pe press c_vpress vol
restart 500000000 simulation*.restart
timestep 0.011214
#ANALYZEDATA
run 500000000
