Hi Axel,
I’m moving on to some phonon calculations of the SiGe system and hope you can see to these (shorter) questions regarding fitfc and fitsvsl.
Trange.in is 1000 20.
I examined the fvib output for each structure from both routines, and found the values from fitfc are very large, and it looks like it contains the total energy of the structure, rather than the additional part, but for fitsvsl it is not the case, only the additional contribution is there. As an example, the Si end member:
E0 = -11.910908
fvib from fitfc:
-11.7892
-11.7896
-11.793
-11.8009
-11.8135
-11.8306
-11.8517
-11.8766
-11.9049
-11.9361
-11.9701
-12.0067
-12.0455
-12.0865
-12.1296
-12.1745
-12.2212
-12.2695
-12.3194
-12.3708
fvib from fitsvsl:
0.119498
0.119391
0.119173
0.118585
0.117413
0.115553
0.112954
0.10959
0.105455
0.100555
0.0949051
0.0885278
0.0814478
0.0736921
0.0652877
0.0562614
0.0466391
0.0364454
0.0257039
0.0144367
In turn, the zeroth order of fvib.eci is very large for fitfc,
fvib.eci from fitfc at T = 0:
-11.0014
0.380551
-0.00111
-0.000327052
-0.000664653
-0.000799553
-0.000391742
0.000117978
0
-0.00100126
while that from fitsvsl at T = 0 :
0.0954644
-0.0121116
-3.655e-05
8.48722e-07
2.01175e-06
-4.0717e-08
-1.71708e-06
-6.18027e-07
0
-8.13645e-06
So my question is, will there be a double counting?
Also, I noticed that before doing the vasp runs for each displacement, fitfc procedure will ask the user to relax the different strained vol_*, but the fitsvsl procedure directly skips that and goes on calculating each displaced cells. Will that lead to errors?
