Dear Axel,
Looks like I have 3 options:
1. Use a hybrid pair style with one non-interacting component
So here I could use my Airebo pair style and also a non-interacting one
like the lj/cut style with epsilon set to 0.0
Seems I have to use types rather than groups if I go down this road.
Would this mean I'd be restricted to two atom types? -at the moment, I
no.
have up to 5 atom types and I use each type for a specific purpose later
on. Is this a problem or can I have one atom type for the
non-interacting pair style and include all the other atom types in the
Airebo pair style?? Then just before firing, I change the atom type of
yes.
the current firing round to one of the types that has Airebo defined for
yes.
it? Not sure how to reset atom types but can look it up. Currently I
there is a command "set"
have this in my input file:
pair_style airebo 0 0 0
pair_coeff * * CH.airebo C C C
What would the syntax look like (roughly) if I had Airebo for types 1-5
and lj/cut for type 6?
please read the documentation for pair style hybrid.
2. As you say I could initially have the layers separated and either
just fire from the separated layers or move each layer into position
before firing - I'm trying to avoid this approach though. Ideally it
would be nice to fire from the same plane
you didn't get me. you have 3 positions:
A-----B---C
A is your target. B is the firing position. C is your reservoir that
hosts *all* "projectiles". B and C are just far enough apart so that
atoms don't interact anymore. atoms at A are in group mobile, atoms at
C are not time integrated.
then you use fix move on group1 to move these atoms from position C to
B. this ignores any forces.
then you remove fix move set the velocity for impact on group1 and add
them to the mobile group. from now on those atoms get time time
integrated like all A atoms and any subsequent operations on the
mobile group includes them.
when you decide to be ready for the next short, you use fix move on
group2 to move it from C to B (load), unfix (lock), set velocity
(aim), and add to the mobile group (shoot).
rinse and repeat until done.
3. neigh_modify group exclude
This seemed easy to do and it even works for the first firing round...Id
love to know how to fix this- even just for the sake of knowing
then construct a minimal test system (just a few atoms) that
demonstrates how you think it should work and doesn't, so that
somebody can look into it.
