Hi all,
Two announcements:
- The FWS docs location has changed again (this time hopefully permanently), but there is an auto-redirect from the previous location. I plan to keep the redirect in place as long as possible, i.e., as long as that domain is intact.
The new location is https://materialsproject.github.io/fireworks/
If you try the older location (https://hackingmaterials.lbl.gov/fireworks/), it will just redirect you automatically.
- There is a new scheme to simplify file-passing between Fireworks in a Workflow as implemented by S.P. Ong. Some docs on it here in case you are interested:
https://materialsproject.github.io/fireworks/guide_to_writing_firetasks.html#file-passing-workflows
Thanks all for your patience as we found a new home for the FWS docs after pythonhosted.org’s sunset.
Anubhav
