I am Tuan Ho from geochemistry department, Sandia National Labs
I am trying to insert CO2 into an empty box using gcmc command. (Lammps 7Dec2015 version). I attached the input file and CO2 molecule file.
My problem is that when I use:
pair_style lj/cut/coul/long 12
kspace_style pppm 0.0001
the simulation will not run. ERROR: Could not compute g_ewald (…/pppm.cpp:1277)
But when I use
pair_style lj/cut/coul/cut 12
It run well.
My question is: does gcmc work with long range interactions? Reading Lammps descripsion it seems to me that it should. For some reason it didn’t work for me.
(../pppm.cpp:1277)
But when I use
It run well.
for me.
if you start from an empty box, the algorithm that tries to guess the
ewald/pppm parameters from setting the convergence only won't work.
try determining them from a test calculation with a full box of the
same size and then set them manually.
