Hi all
I want to integrate equations of motion using fifth order gear predictor-corrector algorithm. I think that option is not there in 21st may’12 lammps. How to add it into lammps? Please explain me in little detailed way.
Thanks and regards
Hi all
Thanks and regards
Hi all
why??
I think that option is not there in 21st may'12 lammps.
no. LAMMPS uses a velocity verlet integrator.
detailed way.
the "little details" explanation is:
just don't do it.
I agree with Axel that you should think about why
you want to do this. MD has a long history of people
trying different integrators, and always coming back
to velocity Verlet. In particular high-order integrators
are not generally effective at increasing the timestep
size.
That said, you could write a fix that does some
different kind of integration, so long as you understand
at what point in the velocity-Verlet-like timestep,
the different fix methods are invoked.
