I have been wondering about the results for calculations in VASP using symmetrized or conventional_standard cif format from materialsproject database.
For example, the compound HgBa2CuO4 (mp-6562) has 8 atoms in its conventional_standard cif:
1 Ba Ba0 0.50000 0.50000 0.69560 1.000 0.000 1a 1
2 Ba Ba1 0.50000 0.50000 0.30440 1.000 0.000 1a 1
3 Cu Cu2 0.00000 0.00000 0.50000 1.000 0.000 1a 1
4 Hg Hg3 0.00000 0.00000 0.00000 1.000 0.000 1a 1
5 O O4 0.00000 0.00000 0.79497 1.000 0.000 1a 1
6 O O5 0.00000 0.00000 0.20503 1.000 0.000 1a 1
7 O O6 0.00000 0.50000 0.50000 1.000 0.000 1a 1
8 O O7 0.50000 0.00000 0.50000 1.000 0.000 1a 1
which naturally agrees with its chemical formula.
On the other hand, the “symmetrized” format has only 5 atoms:
x y z Occ. U Site Sym.
1 Ba Ba0 0.50000 0.50000 0.30440 1.000 0.000 2h 4mm
2 Cu Cu1 0.00000 0.00000 0.50000 1.000 0.000 1b 4/mmm
3 Hg Hg2 0.00000 0.00000 0.00000 1.000 0.000 1a 4/mmm
4 O O3 0.00000 0.00000 0.20503 1.000 0.000 2g 4mm
5 O O4 0.00000 0.50000 0.50000 1.000 0.000 2e mmm .
which I think it has assumed symmetry with respect the z = 0.5 plane.
(by the way, why is this so? isn’t the lattice symmetry only given by unit (+/- 1) increments of the a,b,c lattice vectors?)
May I know which CIF type is the generally preferred choice for calculations?
I tend to use conventional_standard because of its alignment with the chemical formula.
However, in some papers reporting crystallographic positions of a material, for example,
Q. Huang et al., Phys. Rev. B 52, 462 (1995)
they tend to do so in the z=0.5 symmetrized positions.
(In this paper, they write only coordinates for 1 Ba atom only instead of 2 Ba atoms)
Hence, I wonder whether it is more common to use “conventional_standard” CIF or to use “symmetrized” cif ?
Should we expect a different result from these two?
