Generating Cluster Output from corrdump
To whom it may concern,
I am attempting to use the corrdump program with the -rnd command to generate output from the clusters formed for a particular structure. I want to specify the structures to include and then use the -rnd command to output a string of numbers.
Essentially I will give it the input file of str.out and specify the two and three body clusters we want from the program to output.
