I want to generate random number every time, but seems following command is only providing me a constant number.
variable number equal ceil(random(1,1,10)*10000)
print ${number}
That is because you give it a range from 1 to 1.
The number returned is an integer.
So try something like the following:
variable number equal ceil(random(1,1000000000,10)/100000.0)
print ${number}
print ${number}
print ${number}
print ${number}
print ${number}
print ${number}
clear
atom_style atomic
atom_modify map array
atom_modify sort 0 0.0
variable lp equal "3.33"
lattice bcc ${lp} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region whole block 0 1 0 1 0 1 units lattice
create_box 3 whole
create_atoms 1 region whole
replicate 3 3 3
group iron type 1
print ${number}
set group iron type/fraction 2 0.203703704 ${number}
set group iron type/fraction 3 0.055555556 ${number}
mass * 1
# ---------- Define Interatomic Potential ---------------------
pair_style lj/cut 3.0
pair_coeff * * 1 1
neighbor 2.0 bin
neigh_modify delay 10 check yes
run 0
every time it is printing 2355, I want different number with every run
Then you have to use a different seed for each run!
The whole point of having pseudo random number generators with a seed is to make calculations repeatable. If your shell is bash, this can be easily done by using the random number generator embedded in bash.
variable rnseed index 10
variable number equal ceil(random(1,1000000000,${rnseed})/100000.0)
print ${number}
and then using:
./lmp -in in.random -v rnseed $RANDOM
I have to correct my statement. After reviewing the source code, I realize that the reported value from the random function is a double precision floating-point number and not an integer. The problem is, however, giving a range of 1 to 1, which is no range at all. So if you want random numbers between 0 and 1 as it seems you want to get, you would have to use random(0,1,${rnseed})
Thanks a lot !!!
