Generating the same random chain
I’d like to generate a polymer melt consisting of a random copolymer. But I want all the chains to have the same microstructure. Reading the docs did not help but I may have missed a point. Is there any way to do that ?
Here is my input :
#!/usr/bin/env emc_setup.pl
# Options
ITEM		OPTIONS
field_debug reduced
replace		true
# mass		true
# ntotal	1
density		0.7
number          true
field		opls-aa
build_dir	.
ITEM		END
# Groups
ITEM		GROUPS
CBM         *C/C=C\C*, &
        1,CBM:2,  1,TBM:2,  1,VBM:2,  1,STM:2,  1,HT:1, &
        2,CBM:1,  2,TBM:1,  2,VBM:1,  2,STM:1,  2,HT:1
TBM         *C/C=C/C*, &
VBM         *C(C*)C=C, &
STM         *CC(C1=CC=CC=C1)*, &
HT          *H
ITEM		END
# Clusters
ITEM		CLUSTERS
poly		random	1
ITEM		END
# Polymers
ITEM	POLYMERS
poly
1		CBM,10,TBM,10,VBM,10,STM,10,HT,2
ITEM	END
Dear user,
To understand you correctly: you have a random copolymer of CBM, TBM, VBM, and STM, for which no predefined pattern is set and you strive for n exact copies?
If this is the case, you are aiming for a pseudo-random result, which would mean, that the user has to define the randomness of one chain. You can do this by using the block instead of the random cluster option. This allows you to define an exact sequence in your ITEM POLYMERS section, e.g.
# Clusters
ITEM	CLUSTERS
poly	block, 20
ITEM	END
# Polymers
ITEM	POLYMERS
poly
1		CBM,2,TBM,1,CBM,1,VBM,1,VBM,1,STM,1,...,HT,2
ITEM	END
where ... means that you would have to complete the sequence such, that your boundary condition of having a total of 10 CBM, TBM, VBM, and STM repeat units. The sequence would start with
[HT][CBM][CBM][TBM][CBM][VBM][VBM][STM][...][HT]
where [HT] is added as terminator. Please note that EMC can be finicky with respect to partial charge designation when using a single hydrogen as terminator.
The above would generate 20 clusters with the exact same sequence, since you set number to true under ITEM OPTIONS.
Dear veld,
Thanks for your reply, that’s exactly what I was thinking. Terminal H are not a problem, as I parse output pdb to use it for Gromacs. But I will keep that in mind in case of using with LAMMPS.
Thank you again !
Dear veld,
I noticed a strange behaviour. The attached input
# Options
ITEM		OPTIONS
field_debug     reduced
replace		true
density		0.7
number          true
field		opls-aa
build_dir	.
ITEM		END
# Groups
ITEM		GROUPS
CBM         *C/C=C\C*, &
TBM         *C/C=C/C*, &
VBM         *CC(*)C=C, &
HT          *H
ITEM		END
# Clusters
ITEM		CLUSTERS
poly		alternate	1
ITEM		END
# Polymers
ITEM	POLYMERS
poly
1    CBM,1,TBM,1,STM,1,CBM,1,STM,1,CBM,1,VBM,1,CBM,1,STM,2,TBM,1,VBM,1,TBM,1,CBM,1,STM,1,TBM,1,CBM,1,TBM,2,CBM,1,STM,1,VBM,1,STM,2,TBM,1,CBM,1,VBM,1,CBM,1,STM,1,TBM,1,VBM,2,TBM,2,STM,1,TBM,1,CBM,1,VBM,2,STM,2,CBM,1,VBM,1,CBM,1,VBM,1,STM,1,VBM,1,CBM,1,TBM,2,STM,1,TBM,1,STM,3,CBM,1,TBM,1,STM,1,TBM,1,VBM,1,STM,1,TBM,1,VBM,1,STM,1,VBM,1,TBM,1,STM,1,CBM,1,TBM,3,STM,1,CBM,2,TBM,2,STM,3,CBM,2,TBM,2,STM,1,TBM,1,CBM,1,TBM,1,CBM,3,STM,1,CBM,1,STM,1,VBM,1,CBM,1,VBM,1,TBM,1,VBM,1,STM,2,TBM,1,CBM,1,TBM,3,VBM,1,CBM,1,TBM,1,VBM,1,TBM,1,VBM,1,TBM,1,STM,1,VBM,1,TBM,3,CBM,1,VBM,1,CBM,1,VBM,1,STM,1,CBM,1,STM,2,CBM,1,VBM,2,TBM,1,VBM,4,STM,2,VBM,1,CBM,1,TBM,1,VBM,1,CBM,1,TBM,1,CBM,1,VBM,1,TBM,1,CBM,1,TBM,1,STM,1,TBM,1,STM,1,CBM,1,VBM,3,STM,1,CBM,1,TBM,1,VBM,2,CBM,1,VBM,2,CBM,1,STM,1,VBM,1,CBM,2,TBM,1,VBM,1,CBM,1,STM,1,CBM,1,TBM,1,VBM,1,STM,1,CBM,3,VBM,1,STM,1,CBM,2,STM,1,VBM,4,STM,2,CBM,1,VBM,1,STM,1,VBM,1,TBM,2,STM,1,VBM,1,TBM,1,STM,2,CBM,1,HT,2
ITEM	END
produces a pdb (attached) where repeat units are in different order.
Do you have any explaination ?
system.pdb (177.8 KB)
Dear user,
Please note that an alternating polymer does not resemble a sequence, i.e.
CBM,3,STM,3
results in three alternating CBM and STM,
[CBM][STM][CBM][STM][CBM][STM]
If you intend to have three CBM followed by three STM you should define your polymer as follows:
CBM,1,CBM,1,CBM,1,STM,1,STM,1,STM,1
which results in
[CBM][CBM][CBM][STM][STM][STM]
Alternatively, one can input a sequence by using the keyword block, for which
CBM,3,STM,3
results in
I adapted my response from April 15, 2024 accordingly.
Dear veld, thank you for the clarification.
