genstr with symm. equivalent structure
I was wondering if there is also an option where ATAT also generates the symmetry equivalent structures of the symmetry inequivalent structures that we find using genstr command. (Assume genstr produced bunch of symm inequivalent structures, I take one of them and try to find how many symm equivalent structures that one can produce using that specific structure.)
Kind regards,
Yetkin
That problem is not well-defined if you consider multiple possible supercells: a larger supercell structure may happen to have a shorter periodicity - do you then consider it equivalent to a smaller-cell structure?
If the cell is fixed, then it should be easy to implement using the icamag code as a starting point.
