Get data from the Catalysis Explorer
Is there a way to get mp-ids and some properties from the Catalysis Explorer tab from Materials Project but didn’t know how since the properties from the site are not in MPDataDoc.
I saw that the info from the Catalysis Explorer tab is contributed by the Open Catalyst Project so I assume it’s a little different?
Basically I ultimately want to get a dataset of materials with their mpid and adsorption energy for H.
Thanks in advance!
The data contributed by the Open Catalyst Project (MPContribs landing page) can be retrieved programmatically using the mpcontribs-client library. Since it’s a pretty big dataset I recommend using an appropriate query to reduce the number of results and also restrict the returned fields. The list of filters is available here. Below some example code.
from mpcontribs.client import Client
client = Client(project="open_catalyst_project")
# example queries - filters can be combined in same `query`
query = {"data__mpid__in": ["mp-134", "mp-871"]}  # filter by MP id's
query = {"formula__contains": "Fe"} # filter formula by substring
query = {"data__adsorptionEnergy__gt": 0.5} # filter by adsorption energy
fields = [  # fields to return
    "id", "identifier", "formula", "data.mpid", "data.adsorptionEnergy"
client.query_contributions(query=query, fields=fields, paginate=True)
Thank you!! This helps a lot~
Hi!
I am trying to search for binding energies of different intermediates using Catalysis Explorer. But whenever I search for a specific metal like Pd, etc., it starts refresehing and I get nothing. Can you help me in this regard?
@Luqman_Hakeem thanks for reporting this. I’m able to reproduce it and will look into deploying a fix as soon as possible. Thank you for your patience.
I want to access the data from open catalyst explorer through mp contribs.client. While accessing, it shows the error in the line for
client = Client(project=“open_catalyst_project”)
as,
Healthcheck for https://contribs-api.materialsproject.org failed (502)! Wait 30s.
WARNING:mpcontribs.client:Healthcheck for https://contribs-api.materialsproject.org failed (502)! Wait 30s.
Could not connect to https://contribs-api.materialsproject.org
HTTPBadGateway                            Traceback (most recent call last)
/tmp/ipykernel_1281/461161180.py in <cell line: 0>()
----> 1 client = Client(project="open_catalyst_project")
Help me to rectify this
Hi @jeniagar , thanks for bringing this to our attention, sorry that you are experiencing difficulties.
While we investigate on our end, can you tell me which version of the mp-api client you are using?
Considering the topic you posted in, I assume you are using the client from MPContribs directly?
Our most up-to-date client is in the mp-api package. Can you attempt to access the data through that client and let me know the results?
