Dear lammps users,
I’m computing unwrapped atomic coordinates of angles in my own angle sytle, but I get garbled somewhat upon applying periodic boundary conditions.
The compute method of my angle style cpp is as follows, is there something wrong?
void AngleXXX::compute(int eflag, int vflag)
double x1unwrap[3],x2unwrap[3],x3unwrap[3];
double **x = atom->x;
int **anglelist = neighbor->anglelist;
int nanglelist = neighbor->nanglelist;
imageint *image = atom->image;
for (n = 0; n < nanglelist; n++) {
i1 = anglelist[n][0];
i2 = anglelist[n][1];
i3 = anglelist[n][2];
domain->unmap(x[i1],image[i1],x1unwrap); // x1unwrap, x2unwrap and x3unwrap are not what I want
domain->unmap(x[i2],image[i2],x2unwrap); //
domain->unmap(x[i3],image[i3],x3unwrap); //
cx = (x1unwrap[0] + x2unwrap[0] + x3unwrap[0])/3.0;
cy = (x1unwrap[1] + x2unwrap[1] + x3unwrap[1])/3.0;
cz = (x1unwrap[2] + x2unwrap[2] + x3unwrap[2])/3.0;
Best Regards
Zhou
Dear lammps users,
Yes, there should be no need to unwrap coordinates. LAMMPS will use the nearest copy of an atom for any bonded interactions automatically.
> Dear lammps users,
Thanks to Axel. Actually, I use triangular mesh to build a close surface. The triangle is present by angle. I want compute the centre of the surface, so if I use wrap coordinates, I will get erroneous results when the surface through periodic boundary.
Dear lammps users,
conditions.
wrong?
you do not get wrapped coordinates. that is part of how LAMMPS does
domain decomposition. please familiarize yourself better with how
LAMMPS works internally and provide conclusive proof, that my
statement is incorrect. if you don't get the correct result, it is
most likely due to other mistakes, e.g. inconsistent input data or
incorrect code.
apart from that, your triangulated surface is probably better
implemented as a fix style. please check out the LIGGGHTS code that
provides such a feature for granular media.
