Getting help to solve the error for "Bond atoms 5282 5291 missing on proc 0 at step 2515 (src/ntopo_bond_all.cpp:61)"
Hi there!
I am running a system of L-serine substrate, using CHARMM force field. During the process of NPT and getting the final results, I have faced the following error:
“ERROR on proc 0: Bond atoms 5282 5291 missing on proc 0 at step 2515 (src/ntopo_bond_all.cpp:61)
Last command: run 2000000”
Could anyone please help me to resolve this issue?
In case it is needed, I have attached my error script here.
Nlocal: 2100.00 ave 2247 max 1987 min
Histogram: 1 0 0 1 1 0 0 0 0 1
Nghost: 6318.25 ave 6521 max 6203 min
Histogram: 1 1 1 0 0 0 0 0 0 1
Neighs: 308664.0 ave 355784 max 277249 min
Histogram: 1 0 1 1 0 0 0 0 0 1
Total # of neighbors = 1234654
Ave neighs/atom = 146.98262
Ave special neighs/atom = 8.8571429
Neighbor list builds = 917
Dangerous builds = 23
fix 1 all npt temp 300.0 300.0 100.0 iso 2.0 2.0 1000.0
#Exports …
timestep 1
thermo 1000
thermo_style custom step cpu temp pe ke etotal ecoul epair density
dump 1 all atom 1000 dump.txt
run 2000000
PPPM initialization …
using 12-bit tables for long-range coulomb (src/kspace.cpp:340)
G vector (1/distance) = 0.25589473
grid = 32 32 15
stencil order = 5
estimated absolute RMS force accuracy = 0.033822043
estimated relative force accuracy = 0.00010185408
using double precision FFTW3
3d grid and FFT values/proc = 8820 4096
Setting up Verlet run …
Unit style : real
Current step : 2468
Time step : 1
Per MPI rank memory allocation (min/avg/max) = 16.76 | 17.04 | 17.16 Mbytes
Step CPU Temp PotEng KinEng TotEng E_coul E_pair Density
2468 0 200 -468802.56 5007.1647 -463795.4 -576685.27 -668312.3 0.71883945
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
This typically means your simulation had bad dynamics. This could be due to incorrect force field parameters, too large a timestep, etc. One thing that stands out is you had 23 “dangerous” neighborlist builds, which means that you need to increase the neighbor “skin” distance or decrease the timestep.
