Hi all,
I know that compute coord/atom calculates the coordination number for each atom in a group. I was wondering if there is any way to not only get the number of atoms, but also the ids of those atoms. I know I could output the full neighbor list, but in that case I would get all the atoms inside the lj cutoff distance and I just want those that are in the cutoff defined in this compute. Is there any way for doing this?
Thanks a lot.
Hi all,
i don't think, compute coord/atom is the right place to look for the
information you are looking for.
instead, i would try to set up a post-processing calculation for using
rerun and then set the cutoff to the desired value and use compute
pair/local to output the matching pairs.
