Gibbs workflow error
Running the Gibbs workflow in the atomate tutorial I, I get the following error on the Elastic Tensor Fitting Firework:
File “/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/fireworks/core/rocket.py”, line 253, in run
m_action = t.run_task(my_spec)
File “/global/u2/a/ardunn/tutorials/atomate_dev/codes/atomate/atomate/vasp/firetasks/parse_outputs.py”, line 547, in run_task
coll.insert_one(gibbs_dict)
File “/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/collection.py”, line 670, in insert_one
bypass_doc_val=bypass_document_validation),
File “/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/collection.py”, line 575, in _insert
check_keys, manipulate, write_concern, op_id, bypass_doc_val)
File “/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/collection.py”, line 556, in _insert_one
check_keys=check_keys)
File “/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/pool.py”, line 482, in command
self._raise_connection_failure(error)
File “/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/pool.py”, line 610, in _raise_connection_failure
raise error
InvalidDocument: Cannot encode object: array([-10.88950285])
All other fireworks (all transmuters, bulk optimization) launch and finish successfully . Has anyone else had this problem and/or know how to fix it?
If I’m not mistaken, this happens sometimes when trying to store numpy arrays with pymongo.
Alex
Yes this would happen when trying to stick a numpy array in pymongo
Feel free to open a ticket in atomate Github issues. The quick fix is to use monty’s jsanitize() on the object but it would be better if someone actually converted the numpy arrays to list first. Probably Kiran or Brandon would be the one to do it.
Anubhav
File "/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/fireworks/core/rocket.py", line 253, in run
File "/global/u2/a/ardunn/tutorials/atomate_dev/codes/atomate/atomate/vasp/firetasks/parse_outputs.py", line 547, in run_task
File "/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/collection.py", line 670, in insert_one
File "/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/collection.py", line 575, in _insert
File "/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/collection.py", line 556, in _insert_one
File "/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/pool.py", line 482, in command
File "/global/homes/a/ardunn/.conda/envs/atomate_dev_env/lib/python2.7/site-packages/pymongo/pool.py", line 610, in _raise_connection_failure
raise error
Alex
You received this message because you are subscribed to the Google Groups “atomate” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/atomate/e447febb-98c3-426c-9cb6-ca330aa7fe1f%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Anubhav
