- What I tried to do.
Compile 2023 Aug 02 stable release to local Linux server cluster with
- Intel compiler 21.3
- Cmake 3.19.5
- Gcc 9.3.0
- What happened.
Configuration using cmake was done without any errors. But the build crashed with gmake error as following:
[ 95%] Building CXX object CMakeFiles/lammps.dir/home/Sourcecode_LAMMPS_20240305_stablerelease_20230802ver/src/KOKKOS/pair_reaxff_kokkos.cpp.o
icpc: command line warning #10121: overriding '-xHost' with '-xCORE-AVX512'
": internal error: 101003_1112
compilation aborted for /home/Sourcecode_LAMMPS_20240305_stablerelease_20230802ver/src/KOKKOS/pair_reaxff_kokkos.cpp (code 4)
gmake[2]: *** [CMakeFiles/lammps.dir/home/Sourcecode_LAMMPS_20240305_stablerelease_20230802ver/src/KOKKOS/pair_reaxff_kokkos.cpp.o] Error 4
gmake[1]: *** [CMakeFiles/lammps.dir/all] Error 2
gmake: *** [all] Error 2
Looks like kokkos reaxff creates the error, but I donât know what is the problem. How can I escape form gmake error crash?
- Local CPU environment = Intel Skylake Xeon Server CPU (AVX512) architecture
grep avx /proc/cpuinfo | uniq:
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb cat_l3 cdp_l3 intel_ppin intel_pt mba tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm cqm mpx rdt_a avx512f avx512dq rdseed adx smap clflushopt clwb avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local ibpb ibrs stibp dtherm ida arat pln pts pku ospke spec_ctrl intel_stibp arch_capabilities
- Cmake configuration.
I tested with and without âmostâ preset but that didnât make any change.
cmake -C ../cmake/presets/myintel1_213full2_flag1.cmake \
-DCMAKE_INSTALL_PREFIX=/home/Sourcecode_LAMMPS_20240305_stablerelease_20230802ver \
-D PKG_KOKKOS=ON -D Kokkos_ARCH_SKX=yes \
-D Kokkos_ENABLE_CUDA=no -D Kokkos_ENABLE_OPENMP=yes -D Kokkos_ENABLE_SERIAL=yes \
-D PKG_ATC=yes -D PKG_MPIIO=yes -D BUILD_MPI=ON -D PKG_INTEL=yes -D INTEL_LRT_MODE=threads \
-D PKG_ASPHERE=yes -D PKG_CLASS2=yes -D PKG_KSPACE=yes \
-D PKG_MANYBODY=yes -D PKG_MISC=yes -D PKG_MOLECULE=yes \
-D PKG_RIGID=yes -D PKG_OPT=yes -D PKG_REPLICA=yes -D PKG_OPENMP=yes -D PKG_REAXFF=yes \
-D PKG_EXTRA-FIX=yes -D PKG_EXTRA-DUMP=yes -D PKG_EXTRA-COMPUTE=yes -D PKG_EXTRA-MOLECULE=yes -D PKG_EXTRA-PAIR=yes \
../cmake 2>&1| tee configure.log
- Intel preset configuration.
set(CMAKE_CXX_COMPILER "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/compiler/2021.3.0/linux/bin/intel64/icpc" CACHE STRING "" FORCE)
set(CMAKE_C_COMPILER "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/compiler/2021.3.0/linux/bin/intel64/icc" CACHE STRING "" FORCE)
set(CMAKE_Fortran_COMPILER "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/compiler/2021.3.0/linux/bin/intel64/ifort" CACHE STRING "" FORCE)
set(MPI_CXX "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/compiler/2021.3.0/linux/bin/intel64/icpc" CACHE STRING "" FORCE)
set(MPI_CXX_COMPILER "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/mpi/2021.3.0/bin/mpicxx" CACHE STRING "" FORCE)
unset(HAVE_OMP_H_INCLUDE CACHE)
set(OpenMP_C "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/compiler/2021.3.0/linux/bin/intel64/icc" CACHE STRING "" FORCE)
set(OpenMP_C_FLAGS "-qopenmp -qopenmp-simd" CACHE STRING "" FORCE)
set(OpenMP_C_LIB_NAMES "omp" CACHE STRING "" FORCE)
set(OpenMP_CXX "/lstr/applications/atom/compiler/oneAPI/2021.3.0.3219/compiler/2021.3.0/linux/bin/intel64/icpc" CACHE STRING "" FORCE)
set(OpenMP_CXX_FLAGS "-qopenmp -qopenmp-simd" CACHE STRING "" FORCE)
set(OpenMP_CXX_LIB_NAMES "omp" CACHE STRING "" FORCE)
set(OpenMP_Fortran_FLAGS "-qopenmp -qopenmp-simd" CACHE STRING "" FORCE)
set(OpenMP_omp_LIBRARY "libiomp5.so" CACHE PATH "" FORCE)
