I’m simulating gold nanoparticle by lammps.
My in.file is showed below.
atom_style sphere
lattice fcc 4.07
region box sphere 0 0 0 0.708 units lattice
create_box 1 box
change_box triclinic
create_atoms 1 region box
set group all diameter 3.58
set type 1 mass 196.96
pair_style eam
pair_coeff * * Au_u3.eam
velocity all create 310.0 234242
fix 1 all nvt/sphere temp 300.0 300.0 100.0
timestep 0.000001
thermo 500
thermo_modify lost ignore norm no
dump 1 all xyz 100 dump.xyz
run 10000
min_style hftn
minimize 1.0e−4 1.0e−6 1000 1000
variable natoms equal “count(all)”
print “Number of atoms = ${natoms};”
when I run it, Lammps gives error that I do not know How can I solve it?: ERROR: Cannot set mass for this atom style.
Please guide me
thank you
Fatemeh Ramezani
I'm simulating gold nanoparticle by lammps.
atom_style sphere
lattice fcc 4.07
create_box 1 box
pair_style eam
timestep 0.000001
thermo 500
run 10000
min_style hftn
minimize 1.0e-4 1.0e-6 1000 1000
variable natoms equal "count(all)"
print "Number of atoms = ${natoms};"
Please guide me
why did you choose this atom style (sphere)
over the default (atomic)? there is not need for it.
More specifically, if you use atom_style sphere
then mass is set on a per-particle basis, not per-type.
As Axel says, you should probably by using atom_style atomic.
