Good amorphous silica structure by BKS
Hi everybody.
I am trying to obtain amorphous silica structure at 2.2 g/cm^3. I am using BKS potental (LAMMPS version is 2020 March 3). I use two types of simulation.
  1. I use “read_data” to read the input quartz cell of 9 atoms and replicate it, and then after minimization I use “create velocity” command and then start melting and quenching with NPT. But my quartz instantly collapses then the density becomes even higher.
  2. I create atoms randomly inside a box (I tried different box dimensions to have initial density of 2.2, then smaller, then bigger) and relax them at room temperature. The density always gets bigger in the end then the amorphous density of 2.2 as expected. Plus, during the heating phase the density increases when I increase the temperature while it should be the opposite.
What could be the problem in both cases?
The script of first simulation:
variable		num_dump_frames 			equal 	100
variable		num_particles 				equal 	1944
variable		temperature					equal 	300		    # Initial temperature (K in metal units)
variable 		equilibration_steps			equal 	100000
variable		pressure					equal 	1			# The pressure
variable		cut_off 					equal 	10					# Cut-off distance for the Buckingham term
units			metal
atom_style		charge
timestep	    1e-3
read_data		quartzNew.lmp
replicate		6 6 6
variable		lhalf			equal	((33.26*${num_particles}/1.5)^(1/3))/2
region			orthobox		block	-${lhalf} ${lhalf} -${lhalf} ${lhalf} -${lhalf} ${lhalf}	units box
variable		num_silicon		equal 	${num_particles}/3
variable 		num_oxygen		equal 	${num_particles}/3*2
mass			1 28.085500
mass			2 15.999400
set			    type 1 charge +2.4
set			    type 2 charge -1.2
pair_style    	hybrid/overlay	buck/coul/long	${cut_off}	table	linear 39901
pair_coeff    	1 1		buck/coul/long		0.0	1.0 0.0                					#No interactions between Si atoms
pair_coeff   	1 2		buck/coul/long		18003.757200 0.205205 133.538100
pair_coeff    	2 2		buck/coul/long		1388.773000  0.362319 175.000000			#BKS interaction in PRL 64 1955 (1990)
pair_modify   	shift	yes
pair_coeff    	1 2		table potential_SiO2.TPF Si-O	${cut_off}
pair_coeff    	2 2		table potential_SiO2.TPF O-O	${cut_off}           			#See the potential file for more information
kspace_style	pppm 1.0e-4
neighbor		3.0 bin
neigh_modify	check yes	every 1		delay 0		page  100000 one 10000
group      		Si  type 1
group       	O   type 2
thermo			1000
thermo_style	custom	step  temp  press  pe  vol  fnorm  density
thermo_modify	lost	warn
minimize		0  1.0e-8  100000  10000000
	fix	   f0	all	box/relax  aniso  1.0  vmax  0.001
	unfix	   f0
velocity  		all			create	${temperature}		123
dump            1	all custom	1000	everything.dump		id type x y z
fix				f1		all		npt		temp	${temperature} ${temperature} 1		iso	 ${pressure} ${pressure} 1
restart			100000		TTM_pre_restart_*.mpiio
run 			${equilibration_steps}
unfix			f1
And here is the output:
LAMMPS (3 Mar 2020)
Reading data file ...
  triclinic box = (0 0 0) to (4.916 4.25738 5.4054) with tilt (-0.458 0 0)
  4 by 4 by 6 MPI processor grid
  reading atoms ...
  9 atoms
  read_data CPU = 0.0285988 secs
Replicating atoms ...
  triclinic box = (0 0 0) to (29.496 25.5443 32.4324) with tilt (-2.748 0 0)
  1944 atoms
  replicate CPU = 0.00780056 secs
Setting atom values ...
  648 settings made for charge
  1296 settings made for charge
WARNING: 1 of 39901 force values in table are inconsistent with -dE/dr.
  Should only be flagged at inflection points (../pair_table.cpp:483)
648 atoms in group Si
1296 atoms in group O
Setting up cg style minimization ...
  Unit style    : metal
  Current step  : 0
Per MPI rank memory allocation (min/avg/max) = 5.423 | 5.428 | 5.438 Mbytes
Step Temp Press PotEng Volume Fnorm Density
       0            0   -18048.914   -35197.989    24436.329    290.18526    2.6457518
      66            0   -118610.69   -36922.576    24436.329   0.15372121    2.6457518
Loop time of 0.303545 on 96 procs for 66 steps with 1944 atoms
  Unit style    : metal
  Current step  : 66
WARNING: Energy due to 3 extra global DOFs will be included in minimizer energies
Per MPI rank memory allocation (min/avg/max) = 5.423 | 5.428 | 5.439 Mbytes
     128            0   -18.874279   -37041.512    23204.204    48.317312    2.7862392
Loop time of 0.269849 on 96 procs for 62 steps with 1944 atoms
  Unit style    : metal
  Current step  : 128
Per MPI rank memory allocation (min/avg/max) = 5.425 | 5.43 | 5.439 Mbytes
     128            0   -14.441756   -37041.499    23204.204    48.317253    2.7862392
     145            0   -58585.793   -37076.291    23204.204   0.34455231    2.7862392
Loop time of 0.15236 on 96 procs for 17 steps with 1944 atoms
Setting up Verlet run ...
  Unit style    : metal
  Current step  : 0
  Time step     : 0.001
Per MPI rank memory allocation (min/avg/max) = 5.567 | 5.572 | 5.582 Mbytes
       0          300   -55117.537   -37076.291    23204.204   0.34455231    2.7862392
    1000    665.54568   -2714.7088    -37203.03    21876.836    83.854833    2.9552931
    2000    640.07549     6008.503   -37263.761    22401.288    97.913217    2.8861047
   98000    294.91862    1273.3414   -37408.209    22885.312    74.316524    2.8250637
   99000    311.57424    1282.3418   -37410.219    22921.862     72.48088     2.820559
  100000    305.01153    -231.2718    -37406.47    23012.551    73.820079    2.8094436
Loop time of 197.762 on 96 procs for 100000 steps with 1944 atoms
Performance: 43.689 ns/day, 0.549 hours/ns, 505.658 timesteps/s
Total wall time: 0:03:19
Here are the snapshots at 0 ps and at 1 ps
The code of second simulation:
variable		temperature					equal 	300				# Initial state quantum temperature (K in metal units)
variable 		production_steps 			equal 	1000
variable		pressure					equal 	0					# The pressure maintained by the NVT thermostat
variable		cut_off 					equal 	10					# Cut-off distance for the Buckingham term (Angstrom in metal units)
units			metal
atom_style		charge
timestep	    1e-3
	# variable		lhalf			equal	((${num_particles}/0.2)^(1/3))/2		# Aim for number density 0.1 at the begining.
create_box		2 orthobox
create_atoms	1 random ${num_silicon}  1234 orthobox
create_atoms    2 random ${num_oxygen}   4321 orthobox
mass			1 28.085500
mass			2 15.999400
##### Neighbor style
neighbor		3.0 bin
group      		Si  type 1
group       	O   type 2
# velocity  		all			create	${temperature}		123
# fix				f1		all		npt		temp	${temperature} ${temperature} 1		iso	 ${pressure} ${pressure} 1
variable 		varstep		equal 	step
variable 		vartemp		equal 	temp
variable 		varpress 	equal 	press
variable 		varetotal 	equal 	etotal
variable 		varlx		equal	lx
thermo			1000
	unfix	   f0
reset_timestep 	0
fix				f1		all		npt		temp	${temperature} ${temperature} 0.1		iso	 ${pressure} ${pressure} 1
run 			50000
unfix			f1
fix				f2		all		npt		temp	${temperature} 3000 0.1		iso	 ${pressure} ${pressure} 1
unfix			f2
fix				f3		all		npt		temp	3000 3000 1		iso	 ${pressure} ${pressure} 1
run 			50000
unfix			f3
fix				f4		all		npt		temp	3000 ${temperature} 1		iso	 ${pressure} ${pressure} 1
unfix			f4
fix				f5		all		npt		temp	${temperature} ${temperature} 1		iso	 ${pressure} ${pressure} 1
restart			50000		TTM_pre_restart_*.mpiio
unfix			f5
Here the output:
LAMMPS (3 Mar 2020)
Created orthogonal box = (-17.5312 -17.5312 -17.5312) to (17.5312 17.5312 17.5312)
  4 by 6 by 6 MPI processor grid
Created 648 atoms
  create_atoms CPU = 0.00185729 secs
Created 1296 atoms
  create_atoms CPU = 0.000839393 secs
PPPM initialization ...
  using 12-bit tables for long-range coulomb (../kspace.cpp:332)
  G vector (1/distance) = 0.295882
  grid = 27 27 27
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00124108
  estimated relative force accuracy = 8.61882e-05
  using double precision KISS FFT
  3d grid and FFT values/proc = 2016 175
Neighbor list info ...
  update every 1 steps, delay 0 steps, check yes
  max neighbors/atom: 10000, page size: 100000
  master list distance cutoff = 13
  ghost atom cutoff = 13
  binsize = 6.5, bins = 6 6 6
  2 neighbor lists, perpetual/occasional/extra = 2 0 0
  Unit style    : metal
  Current step  : 0
Per MPI rank memory allocation (min/avg/max) = 5.38 | 5.387 | 5.389 Mbytes
       0            0 3.2026541e+09     25819772     43104.96 3.9596915e+09    1.4998845
    1000            0   -35715.755   -36722.935     43104.96    1.4719804    1.4998845
    1418            0   -36527.461   -36736.989     43104.96   0.13020846    1.4998845
Loop time of 7.64799 on 144 procs for 1418 steps with 1944 atoms
94.5% CPU use with 144 MPI tasks x no OpenMP threads
Minimization stats:
  Stopping criterion = linesearch alpha is zero
  Energy initial, next-to-last, final =
         25819772.0421     -36736.9894136     -36736.9894136
  Force two-norm initial, final = 3.95969e+09 0.130208
  Force max component initial, final = 2.78472e+09 0.0165201
  Final line search alpha, max atom move = 4.76837e-07 7.87742e-09
  Iterations, force evaluations = 1418 2404
  Unit style    : metal
  Current step  : 1418
Per MPI rank memory allocation (min/avg/max) = 5.379 | 5.387 | 5.389 Mbytes
    1713            0   -146.94654   -36792.083    39084.805    3.6492124    1.6541585
Loop time of 11.5688 on 144 procs for 295 steps with 1944 atoms
98.7% CPU use with 144 MPI tasks x no OpenMP threads
Minimization stats:
        -36736.9894136     -36792.0855389     -36792.0855389
  Force two-norm initial, final = 1702.37 11.2702
  Force max component initial, final = 999.002 10.5491
  Final line search alpha, max atom move = 6.37916e-11 6.72941e-10
  Iterations, force evaluations = 295 504
MPI task timing breakdown:
Section |  min time  |  avg time  |  max time  |%varavg| %total
Pair    | 0.0065885  | 0.19125    | 0.35951    |  16.7 |  1.65
Kspace  | 5.3458     | 5.7069     | 6.0823     |   4.1 | 49.33
Neigh   | 6.4848e-05 | 0.0001456  | 0.00025173 |   0.0 |  0.00
Comm    | 0.84002    | 1.2852     | 1.7779     |  10.3 | 11.11
Output  | 0          | 0          | 0          |   0.0 |  0.00
Modify  | 0          | 0          | 0          |   0.0 |  0.00
Other   |            | 4.385      |            |       | 37.91
Nlocal:    13.5 ave 25 max 0 min
Histogram: 2 6 12 10 32 13 38 11 15 5
Nghost:    1668.75 ave 1721 max 1627 min
Histogram: 5 12 22 27 22 21 16 13 5 1
Neighs:    3010.62 ave 6000 max 0 min
Histogram: 4 7 16 15 30 26 22 15 7 2
Total # of neighbors = 433530
Ave neighs/atom = 223.009
Neighbor list builds = 1
Dangerous builds = 0
  G vector (1/distance) = 0.29251
  grid = 25 25 25
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00159111
  estimated relative force accuracy = 0.000110497
  (1) pair buck/coul/long, perpetual
  Unit style    : metal
  Current step  : 1713
Per MPI rank memory allocation (min/avg/max) = 5.354 | 5.368 | 5.382 Mbytes
    1713            0   -146.81631   -36792.073    39084.805    3.6494501    1.6541585
    2000            0   -26258.089   -36855.155    39084.805    1.5663468    1.6541585
    2260            0   -28705.889    -36867.22    39084.805    0.1917403    1.6541585
Loop time of 1.95123 on 144 procs for 547 steps with 1944 atoms
93.2% CPU use with 144 MPI tasks x no OpenMP threads
Minimization stats:
        -36792.0726676     -36867.2203252     -36867.2203252
  Force two-norm initial, final = 3.64945 0.19174
  Force max component initial, final = 0.275649 0.0279626
  Final line search alpha, max atom move = 2.38419e-07 6.6668e-09
  Iterations, force evaluations = 547 1094
Pair    | 0.0018582  | 0.40884    | 0.75569    |  22.7 | 20.95
Kspace  | 0.7253     | 1.0696     | 1.4855     |  14.1 | 54.82
Neigh   | 0.00023502 | 0.00078533 | 0.0012997  |   0.0 |  0.04
Comm    | 0.34849    | 0.36513    | 0.37995    |   1.0 | 18.71
Output  | 0.00012401 | 0.00012532 | 0.00014994 |   0.0 |  0.01
Other   |            | 0.1067     |            |       |  5.47
Nlocal:    13.5 ave 26 max 0 min
Histogram: 3 7 8 24 15 33 29 13 10 2
Nghost:    1708.39 ave 1760 max 1672 min
Histogram: 5 14 25 36 17 19 17 4 6 1
Neighs:    3084.81 ave 6095 max 0 min
Histogram: 4 6 8 27 20 34 17 22 4 2
Total # of neighbors = 444212
Ave neighs/atom = 228.504
Neighbor list builds = 6
  grid = 25 25 25
  stencil order = 5
  Unit style    : metal
  Current step  : 0
  Time step     : 0.001
Per MPI rank memory allocation (min/avg/max) = 4.489 | 5.487 | 5.508 Mbytes
       0          300   -26646.825    -36867.22    39084.805    0.1917403    1.6541585
    1000    343.85313   -564.15007   -36972.811     28932.27    59.436285    2.2346142
    2000    304.95356   -1025.1182   -37071.665    27916.943    55.230618    2.3158862
    3000    279.44108    332.33376   -37092.667    27559.821      59.9403    2.3458956
   48000    302.30967   -756.96403   -37172.927    26766.068    74.543831    2.4154636
   49000    295.92801    1102.7683   -37173.712      26786.5    74.015064    2.4136212
   50000    313.50318   -492.23162   -37170.384    26764.039    75.176159    2.4156467
Loop time of 96.9161 on 144 procs for 50000 steps with 1944 atoms
Performance: 44.575 ns/day, 0.538 hours/ns, 515.910 timesteps/s
90.7% CPU use with 144 MPI tasks x no OpenMP threads
Pair    | 6.2803     | 20.427     | 33.992     | 114.3 | 21.08
Kspace  | 33.92      | 47.289     | 60.747     |  75.6 | 48.79
Neigh   | 0.0044616  | 0.0092983  | 0.01304    |   1.8 |  0.01
Comm    | 20.789     | 21.826     | 22.696     |   8.2 | 22.52
Output  | 0.046474   | 0.04653    | 0.048118   |   0.1 |  0.05
Modify  | 4.2353     | 5.3038     | 6.0309     |  20.1 |  5.47
Other   |            | 2.015      |            |       |  2.08
Nlocal:    13.5 ave 23 max 3 min
Histogram: 2 3 4 16 22 40 32 19 4 2
Nghost:    2313.69 ave 2359 max 2264 min
Histogram: 6 11 7 13 21 29 27 13 14 3
Neighs:    4489.42 ave 8648 max 1073 min
Histogram: 3 5 13 34 33 33 16 4 2 1
Total # of neighbors = 646476
Ave neighs/atom = 332.549
Neighbor list builds = 54
  G vector (1/distance) = 0.299001
  grid = 24 24 24
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00130884
  estimated relative force accuracy = 9.08938e-05
  3d grid and FFT values/proc = 1573 96
  binsize = 6.5, bins = 5 5 5
      attributes: half, newton on
      pair build: half/bin/atomonly/newton
      stencil: half/bin/3d/newton
      bin: standard
  (2) pair table, perpetual, skip from (1)
      pair build: skip
      stencil: none
      bin: none
  Unit style    : metal
  Current step  : 50000
  Time step     : 0.001
Per MPI rank memory allocation (min/avg/max) = 4.487 | 5.481 | 5.507 Mbytes
   50000    313.50318   -506.25913   -37170.414    26764.039    75.176918    2.4156467
   51000    325.43598   -1003.6766   -37165.932    26925.141    79.000562    2.4011931
   52000    348.78456   -1960.7966     -37161.2    26673.295    79.863413    2.4238649
  149000    3033.3578    8452.9713    -36675.97    25940.459    226.05507    2.4923407
  150000    3007.8054   -1526.9646   -36640.964    26157.934    230.87087    2.4716196
Loop time of 188.901 on 144 procs for 100000 steps with 1944 atoms
Performance: 45.738 ns/day, 0.525 hours/ns, 529.379 timesteps/s
89.6% CPU use with 144 MPI tasks x no OpenMP threads
Pair    | 17.589     | 42.889     | 63.904     | 133.5 | 22.70
Kspace  | 58.447     | 80.233     | 105.96     |  99.6 | 42.47
Neigh   | 0.098466   | 0.1645     | 0.22195    |   5.8 |  0.09
Comm    | 44.089     | 46.468     | 48.406     |  13.1 | 24.60
Output  | 0.65792    | 0.65817    | 0.68351    |   0.3 |  0.35
Modify  | 13.264     | 14.255     | 14.883     |   7.1 |  7.55
Other   |            | 4.233      |            |       |  2.24
Nlocal:    13.5 ave 19 max 4 min
Histogram: 1 1 4 2 26 15 41 20 25 9
Nghost:    2383.5 ave 2439 max 2346 min
Histogram: 8 15 19 30 28 21 14 7 0 2
Neighs:    4655.58 ave 7533 max 1167 min
Histogram: 1 2 6 20 28 32 26 20 7 2
Total # of neighbors = 670404
Ave neighs/atom = 344.858
Neighbor list builds = 876
  G vector (1/distance) = 0.29957
  grid = 24 24 24
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00127928
  estimated relative force accuracy = 8.88412e-05
      bin: standard
      pair build: skip
      stencil: none
      bin: none
  Unit style    : metal
  Current step  : 150000
  Time step     : 0.001
Per MPI rank memory allocation (min/avg/max) = 4.499 | 5.483 | 5.507 Mbytes
  150000    3007.8054   -1527.8513   -36640.966    26157.934    230.87082    2.4716196
  151000    3064.7407   -7484.2784   -36668.281    26128.494    222.68537    2.4744045
  152000    2950.1102   -830.59195   -36668.803    26240.596    227.46568    2.4638336
  199000    3082.9038   -874.28135   -36688.239    25980.894    228.43904    2.4884618
  200000    3054.2367   -1401.4104   -36720.677    25924.945     219.5275    2.4938322
Loop time of 94.5546 on 144 procs for 50000 steps with 1944 atoms
Performance: 45.688 ns/day, 0.525 hours/ns, 528.795 timesteps/s
Pair    | 11.504     | 21.741     | 29.614     |  77.9 | 22.99
Kspace  | 31.784     | 39.567     | 50.931     |  60.0 | 41.85
Neigh   | 0.10733    | 0.17659    | 0.22819    |   4.8 |  0.19
Comm    | 22.229     | 23.503     | 24.558     |   9.1 | 24.86
Output  | 0.44179    | 0.44486    | 0.46982    |   0.6 |  0.47
Modify  | 6.5146     | 6.9706     | 7.3849     |   5.8 |  7.37
Other   |            | 2.152      |            |       |  2.28
Nlocal:    13.5 ave 20 max 4 min
Histogram: 1 0 2 8 16 50 36 14 15 2
Nghost:    2392.11 ave 2440 max 2357 min
Histogram: 8 15 17 16 42 20 16 5 3 2
Neighs:    4653.05 ave 7572 max 1519 min
Histogram: 1 3 9 21 35 28 29 7 9 2
Total # of neighbors = 670039
Ave neighs/atom = 344.67
Neighbor list builds = 943
  G vector (1/distance) = 0.299793
  grid = 24 24 24
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00126793
  estimated relative force accuracy = 8.80526e-05
      bin: standard
      pair build: skip
      stencil: none
      bin: none
  Unit style    : metal
  Current step  : 200000
  Time step     : 0.001
Per MPI rank memory allocation (min/avg/max) = 4.499 | 5.483 | 5.508 Mbytes
  200000    3054.2367   -1401.6824   -36720.678    25924.945    219.52749    2.4938322
  201000    2931.7962   -484.79796   -36693.664    25950.465    227.35416    2.4913797
  202000    2872.5191    479.89988   -36707.233    25637.049    226.87716    2.5218371
  298000    395.28186    2002.2487   -37431.669    25434.452    84.723473    2.5419248
  299000    373.13827   -1515.5951   -37439.278    25438.702    79.380137       2.5415
  300000    333.59681   -539.66166   -37442.519    25517.819    80.161317    2.5336203
Loop time of 189.391 on 144 procs for 100000 steps with 1944 atoms
Performance: 45.620 ns/day, 0.526 hours/ns, 528.008 timesteps/s
Pair    | 24.942     | 44.044     | 62.168     | 104.8 | 23.26
Kspace  | 59.963     | 79.133     | 100.18     |  80.6 | 41.78
Neigh   | 0.099859   | 0.15363    | 0.19723    |   4.3 |  0.08
Comm    | 44.382     | 47.198     | 49.083     |  13.3 | 24.92
Output  | 0.89189    | 0.89253    | 0.93998    |   0.5 |  0.47
Modify  | 12.878     | 13.854     | 14.631     |   8.3 |  7.32
Other   |            | 4.115      |            |       |  2.17
Nlocal:    13.5 ave 20 max 7 min
Histogram: 4 0 7 26 40 25 33 5 2 2
Nghost:    2420.05 ave 2463 max 2382 min
Histogram: 4 8 19 20 36 21 16 11 4 5
Neighs:    4723.28 ave 7485 max 2508 min
Histogram: 5 8 16 32 33 20 18 8 1 3
Total # of neighbors = 680153
Ave neighs/atom = 349.873
Neighbor list builds = 809
  G vector (1/distance) = 0.300185
  grid = 24 24 24
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00124809
  estimated relative force accuracy = 8.66753e-05
      bin: standard
      pair build: skip
      stencil: none
      bin: none
  Unit style    : metal
  Current step  : 300000
  Time step     : 0.001
Per MPI rank memory allocation (min/avg/max) = 4.499 | 5.484 | 5.508 Mbytes
  300000    333.59681   -540.60146   -37442.521    25517.819    80.161311    2.5336203
  301000    329.53265     2093.002   -37447.358    25461.899    78.231673    2.5391846
  302000    320.67692   -1505.3053   -37452.013    25454.302    75.217439    2.5399425
  398000    302.96029    12.910631   -37452.992    25495.397    75.360814    2.5358485
  399000    309.50624    2286.0348   -37453.572    25442.566    75.253949     2.541114
  400000    302.62384   -2668.8727   -37454.963    25502.651     75.12892    2.5351271
Loop time of 186.067 on 144 procs for 100000 steps with 1944 atoms
Performance: 46.435 ns/day, 0.517 hours/ns, 537.442 timesteps/s
89.4% CPU use with 144 MPI tasks x no OpenMP threads
Pair    | 24.963     | 43.917     | 66.592     | 118.1 | 23.60
Kspace  | 53.52      | 76.914     | 98.403     |  90.9 | 41.34
Neigh   | 0.0002706  | 0.0004136  | 0.00058636 |   0.0 |  0.00
Comm    | 43.646     | 46.248     | 48.319     |  14.4 | 24.86
Output  | 1.9064     | 1.9068     | 1.9264     |   0.2 |  1.02
Modify  | 12.007     | 13.039     | 13.663     |   8.3 |  7.01
Other   |            | 4.042      |            |       |  2.17
Nlocal:    13.5 ave 19 max 7 min
Histogram: 2 1 7 10 17 72 14 10 6 5
Nghost:    2419.74 ave 2454 max 2397 min
Histogram: 9 12 32 27 19 24 10 5 3 3
Neighs:    4728.12 ave 7434 max 2645 min
Histogram: 6 5 19 40 27 23 12 6 3 3
Total # of neighbors = 680849
Ave neighs/atom = 350.231
Neighbor list builds = 2
System init for write_data ...
  G vector (1/distance) = 0.3002
  grid = 24 24 24
  stencil order = 5
  estimated absolute RMS force accuracy = 0.00124735
  estimated relative force accuracy = 8.6624e-05
      bin: standard
      pair build: skip
      stencil: none
      bin: none
Total wall time: 0:13:00
Impossible to say from remote. There can be many reasons. Have you verified that your tables are correct and you are using matching units?
Two additional, unrelated comments:
  • Your LAMMPS version is very old. An upgrade is strongly recommended so you can benefit from bugfixes of recent 4+ years of development. Also, no LAMMPS developer will seriously look into identifying and fixing a bug in an old version of LAMMPS.
  • running such a small system with 96 MPI processes is overkill. You should reach the strong scaling limit around 10 MPI processes. The simulation will actually be slower with too many processors.
Thank You for your answer.
I started a new simulation with the newest version of LAMMPS, 19 Nov 2024.
And to be sure that the tables are not the reason I am not using any table now, I just use simple BKS potential. I just create randomly 19998 atoms and want to minimize the system. Input below:
	units		metal
	dimension	3
	boundary	p p p
	atom_style	charge
variable		nTotal	 		equal 		19998
variable		dens			equal		2.2
variable		mSi				equal		4.6637066e-23
variable		mO				equal		2.6566962e-23
variable		cm3toA3			equal		1.0e+24
variable		length			equal		(${nTotal}*(${mSi}+(2*${mO}))/3/(${dens}/${cm3toA3}))^(1/3)
region			orthobox		block		0 ${length}  0  ${length}  0 ${length}		units box
variable		nSi				equal 		${nTotal}/3
variable 		nO				equal 		${nTotal}/3*2
	create_atoms	1		random		${nSi}		1234	orthobox
	create_atoms	2		random		${nO}		4321	orthobox
			mass	1	28.085500
			mass	2	15.999400
	pair_style		buck/coul/long	10
	pair_coeff		1 1 	0			1		0			10
	pair_coeff		1 2 	18003.757	4.873	133.538		10
	pair_coeff		2 2 	1388.773	2.760	175.0		10
	kspace_style	ewald	1.0e-4
	neighbor		2		bin
	neigh_modify	every	1	delay 0		check yes
	timestep		0.00048
	thermo			100
#_________________________ Minimization ____________________
	unfix	f0
#___________________________________________________________
write_data	d0.lmp
thermo	1000
	fix		ff		all		npt			temp	0.1 5000 0.1	aniso 0 0 1
run 1000000
	unfix	ff
And the output shows that fnorm and pressure are in the orders of 100 and they never converge:
LAMMPS (19 Nov 2024)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/src/comm.cpp:99)
Created orthogonal box = (0 0 0) to (67.114388 67.114388 67.114388)
  6 by 4 by 4 MPI processor grid
Created 6666 atoms
  using lattice units in orthogonal box = (0 0 0) to (67.114388 67.114388 67.114388)
  create_atoms CPU = 0.003 seconds
Created 13332 atoms
  create_atoms CPU = 0.001 seconds
  6666 settings made for charge
  13332 settings made for charge
Ewald initialization ...
  using 12-bit tables for long-range coulomb (src/src/kspace.cpp:342)
  G vector (1/distance) = 0.29072464
  estimated absolute RMS force accuracy = 0.0015475859
  estimated relative force accuracy = 0.0001074739
  KSpace vectors: actual max1d max3d = 14335 19 29659
                  kxmax kymax kzmax  = 19 19 19
Generated 0 of 1 mixed pair_coeff terms from geometric mixing rule
  update: every = 1 steps, delay = 0 steps, check = yes
  master list distance cutoff = 12
  ghost atom cutoff = 12
  binsize = 6, bins = 12 12 12
  1 neighbor lists, perpetual/occasional/extra = 1 0 0
      bin: standard
  Unit style    : metal
  Current step  : 0
Per MPI rank memory allocation (min/avg/max) = 37.64 | 37.65 | 37.66 Mbytes
         0   0              2.2981905e+09  4.340355e+09   302306.1       8.4899179e+10  2.2000293
        19   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
Loop time of 26.5061 on 96 procs for 19 steps with 19998 atoms
98.5% CPU use with 96 MPI tasks x 1 OpenMP threads
Minimization stats:
  Stopping criterion = quadratic factors are zero
      4340354950.33102 -1.74093894532963e+94 -1.74093894532963e+94
  Force two-norm initial, final = 8.4899179e+10 3.326439e+110
  Force max component initial, final = 5.7452439e+10 2.3521476e+110
  Final line search alpha, max atom move = 8.50916e-135 2.00148e-24
  Iterations, force evaluations = 19 535
Pair    | 0.82767    | 1.1371     | 1.4787     |  11.4 |  4.29
Kspace  | 17.876     | 20.399     | 24.989     |  34.6 | 76.96
Neigh   | 0          | 0          | 0          |   0.0 |  0.00
Comm    | 0.261      | 4.8888     | 7.7168     |  73.1 | 18.44
Other   |            | 0.08115    |            |       |  0.31
Nlocal:        208.312 ave         243 max         169 min
Histogram: 2 1 13 11 14 25 7 10 9 4
Nghost:        3670.97 ave        3819 max        3526 min
Histogram: 2 3 9 14 22 19 14 8 1 4
Neighs:        49835.4 ave       64213 max       36081 min
Histogram: 2 4 8 15 22 20 16 6 1 2
Total # of neighbors = 4784201
Ave neighs/atom = 239.23397
Neighbor list builds = 0
  Unit style    : metal
  Current step  : 19
 (src/src/min.cpp:219)
       100   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
       200   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
       300   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
       400   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
       500   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
       600   0             -1.1792091e+95 -1.7409389e+94  302306.1       3.326439e+110  2.2000293
I also tried the following minimization procedure:
	min_style		fire
	minimize		0 1.0e-6 100000000 10000000
	min_style		cg
	fix				11	all box/relax aniso 0 vmax 0.001
	minimize		0 1.0e-6 10000000 1000000
	unfix			11
	min_style       fire
And the simulation crashed because of the great number of lost atoms:
Created 6666 atoms
  create_atoms CPU = 0.106 seconds
Created 13332 atoms
      bin: standard
Setting up fire style minimization ...
  Unit style    : metal
  Current step  : 0
  Parameters for fire:
    dmax  delaystep dtgrow dtshrink alpha0 alphashrink tmax tmin   integrator   halfstepback   abcfire
     0.1     20      1.1     0.5     0.25     0.99      10  0.02 eulerimplicit      yes          no
Per MPI rank memory allocation (min/avg/max) = 36.52 | 36.53 | 36.53 Mbytes
ERROR: Lost atoms: original 19998 current 14486 (src/src/thermo.cpp:494)
Last command: 	minimize		0 1.0e-6 100000000 10000000
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[460,1],19]
  Exit code:    1
What could possibly be the problem? Can the problem be the BKS coefficients that I use? I took them from the original paper:
And the formulas described in the paper and in LAMMPS are the same.
This is the likely problem in combination with
The problem with this pair style is that unlike Lennard-Jones based pair styles, atoms at short distances are not repelled due to the functional form of the Buckingham potential. Thus, it is required to either avoid close contacts or create a “modified” Buckingham potential with a proper repulsion “splined in”. That is what the tabulated potentials are about that are circulating.
However, the issue should be preventable by using the “overlap” keyword with a sufficient argument to prevent generating atom positions that overlap too closely with other atoms.
