Hello everyone,
I am trying to run LAMMPS with GPU acceleration enabled via the KOKKOS package to do some long molecular dynamics simulations for a few organic molecules dispersed in a polymer matrix. As I failed miserably to build LAMMPS with GPU acceleration myself (some cmath header error that I could not figure out), I asked the HPC center staff to do it for me. And so they built the LAMMPS/29Aug2024 version (their choice).
I then proceeded to adapted the input script, which runs fine for CPU only jobs, by adding /kk in command lines related to the force field setup, which by the way is CGenFF (some "adapted CHARMM version for small organic molecules”). E.g. for now it is looking like this:
units real
atom_style full
bond_style harmonic/kk
angle_style charmm/kk
dihedral_style charmmfsw/kk
special_bonds charmm
improper_style harmonic/kk
pair_style lj/charmmfsw/coul/long/kk 10 12
pair_modify mix arithmetic
kspace_style pppm/kk 1e-6
read_data Last_MS.data
I also tried adding /kk only to a subset of the above. Regardless, once I reach the run command, I always get the error:
ERROR: Dihedral_style charmm/kk requires half neighbor list (src/KOKKOS/dihedral_charmmfsw_kokkos.cpp:84)
I thought the default was to use half of the neighbor list? Does the default change because of the KOKKOS package? Does anyone know how I can fix that? ![]()
Cecilia
