I am currently testing the performance of different LJ and DPD fluids with the GPU package, using the LAMMPS latest feature release (21 Nov 2023). The simulations were run on a single NVIDIA A40 GPU. I found out that, if the box size of a LJ fluid equals or exceeds 13500000 atoms, I get the following error:
ERROR on proc 0: Insufficient memory on accelerator (src/GPU/pair_lj_cut_gpu.cpp:110)
This can be replicated by changing the box size in the “in.melt” file to box block 0 150 0 150 0 150.
Regarding DPD fluids, if the box size equals or exceeds 23328000 atoms, I get the following error:
ERROR on proc 0: Insufficient memory on accelerator (src/GPU/pair_dpd_gpu.cpp:257)
I encountered this after setting the variable L to 180 in the “in.dpd” file. In addition, I noticed that if I set the variable L to a larger number (e.g. 300), I get a different error:
Cuda driver error 700 in call at file '/home/user/mylammps_release_21nov23/lib/gpu/geryon/nvd_timer.h' in line 76.
Is there an upper limit of particles that a single GPU can handle?
Is there a way to fix these errors?
Thank you in advance!
M
