I am simulating hybrid granular system with complex particles, using fix rigid/small. Could you please make a reference to some explanation how the frictional forces are computed in nve integration. I want to understand how the energy dissipation due to these forces is computed. As I understand nve means conservation of energy.
Thank you in advance!
your question is too vague. please be more specific and best provide a
simple example because it is not even clear from your description what
your atom style and general setup is.
nve does not mean "conservation of energy". nve means no (kinetic)
energy added or removed by the integrator.
Well, yes the question is rather vague, because it concernes understanding of principles. I have performed calculations with nve integrator (according to LAMMPS how-to for granular systems) and I want to understand how it is working not diging into C++ code. There should be some described algorithm in litterature, I think, I just do not know where they are.
My system is hybrid sphere dipole bond, pair_style hybrid/overlay gran/hertz/history and dipole/cut. Spheres with dipole moments are grouped in rigid bodies by fix rigid/small molecule, LJ is turned off by coefficient. I study micro granular particles with moments and friction in the external field, so that is mecanical-dipole system.
So if there is a dissipative force (like friction) the energy will be dissipated in the system using nve? And forces are calculated explicitely from the equations described for pair styles, e.g. in the manual, with no regard to energy?
Oksana
Четверг, 30 января 2014, 7:46 -05:00 от Axel Kohlmeyer <akohlmey@…24…>:
LAMMPS uses Velocity Verlet for time integration. fix nve implements
the pure form of it with no additional manipulations. practically
every text book on MD describes it. having a look at the sources would
have shown you.
this makes no sense. it has been explained many, many times that fix
nve does *not* manipulate energies. *that* is what makes the NVE
ensemble (if everything else is consistent with it).
regard to energy?
unless it is explicitly specified, the integrator does not regard
anything but the force on the position of the particle (which is
usually a point particle).
