Hello
I need the GUI of DL_poly 4 for windowsPlz provides me a download link.
Kind Regurds
hello
i just have gui
for ubuntu (linux)
if it is helpful
i can provide
در تاریخ دوشنبه ۱۹ آوریل ۲۰۲۱، ۰:۵۷ farzad kermani <[email protected]> نوشت:
Hi Dear Kianoush,
DL_poly GUI has been written in java and is architecture independent. you can compile it on any machine that has java virtual machine, java developement kit (not so neccessary) and java run-time environment (working jvm, jdk and jre ). Then if you follow the comments provided by developers in readme file (using the commands class, javac) or directly run build file inside java folder in dl_poly root. Please note that dl_poly gui iwas put inside the java folder in dl_poly root directory (e.g. c:\program files\dl_poly\java)
regards,
Prof. Jaber Jahanbin
Kianoush Ramezani shabolaghi wrote:
i cannot send it via email if you want it send me a message via telegram or WhatsApp
