I am trying to modify the lammps demo example of 2D ellipsoid to create a 3D system of ellipsoidal particles. The code stops saying “Lost atoms: original 1000 current 7”. Can anyone help me figure out this problem? My input script is as follows:
SRD diffusion demo - ellipsoids
units lj
atom_style ellipsoid
atom_modify first big
create big ellipsoidal particles
lattice sc 0.4
region box block 0 10 0 10 0 10
create_box 1 box
create_atoms 1 region box
set type 1 mass 1.0
set type 1 shape 3.0 1.0 1.0
group big type 1
set group big quat/random 29898
velocity big create 1.44 87287 loop geom
equilibrate big particles
pair_style gayberne 1.0 3.0 1.0 4.0
pair_coeff 1 1 1.0 1.0 1 1 1 1 1 1
minimize 0.0 1.0e-8 1000 100000
neighbor 0.3 bin
fix 1 big nve/asphere
compute rot big temp/asphere
compute diameter all property/atom shapex shapey shapez
compute q all property/atom quatw quati quatj quatk
dump 1 all custom 10 dump.ellipsoid.equil id type x y z c_diameter[1] c_diameter[2] c_diameter[3] c_q[1] c_q[2] c_q[3] c_q[4]
dump_modify 1 colname c_q[1] quatw colname c_q[2] quati colname c_q[3] quatj colname c_q[4] quatk
dump_modify 1 colname c_diameter[1] shapex colname c_diameter[2] shapey colname c_diameter[3] shapez
thermo_style custom step temp c_rot epair etotal press
thermo 100
run 1000
undump 1
unfix 1
timestep 0.0005
#thermo_modify temp tbig
thermo 1000
dump 1 all custom 1000 dump.ellipsoid id type x y z c_diameter[1] c_diameter[2] c_diameter[3] c_q[1] c_q[2] c_q[3] c_q[4]
run 100000
My output error is:
LAMMPS (23 Jun 2022 - Update 2)
Lattice spacing in x,y,z = 1.3572088 1.3572088 1.3572088
Created orthogonal box = (0 0 0) to (13.572088 13.572088 13.572088)
1 by 2 by 2 MPI processor grid
Created 1000 atoms
using lattice units in orthogonal box = (0 0 0) to (13.572088 13.572088 13.572088)
create_atoms CPU = 0.004 seconds
Setting atom values …
1000 settings made for mass
1000 settings made for shape
1000 atoms in group big
1000 settings made for quat/random
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Your simulation uses code contributions which should be cited:
- pair gayberne command:
The log file lists these citations in BibTeX format.
WARNING: Using ‘neigh_modify every 1 delay 0 check yes’ setting during minimization (../min.cpp:187)
Generated 0 of 0 mixed pair_coeff terms from geometric mixing rule
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 4.3
ghost atom cutoff = 4.3
binsize = 2.15, bins = 7 7 7
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair gayberne, perpetual
attributes: half, newton on
pair build: half/bin/atomonly/newton
stencil: half/bin/3d
bin: standard
Setting up cg style minimization …
Unit style : lj
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 6.031 | 6.031 | 6.031 Mbytes
Step Temp E_pair E_mol TotEng Press
0 1.44 1.9779748e+43 0 1.9779748e+43 -3.4881945e+47
1000 1.44 57.545011 0 59.702851 155.89971
Loop time of 75.7086 on 4 procs for 1000 steps with 1000 atoms
94.3% CPU use with 4 MPI tasks x no OpenMP threads
Minimization stats:
Stopping criterion = max iterations
Energy initial, next-to-last, final =
1.97797480969295e+43 57.5450105571295 57.5450105571295
Force two-norm initial, final = 2.4602815e+51 13261.809
Force max component initial, final = 1.5275392e+51 8768.2891
Final line search alpha, max atom move = 3.5639792e-07 0.003125
Iterations, force evaluations = 1000 7506
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 62.329 | 64.663 | 66.906 | 27.7 | 85.41
Neigh | 0.11416 | 0.12212 | 0.13509 | 2.4 | 0.16
Comm | 8.2391 | 10.526 | 12.836 | 68.8 | 13.90
Output | 2.1197e-05 | 2.4109e-05 | 3.2686e-05 | 0.0 | 0.00
Modify | 0 | 0 | 0 | 0.0 | 0.00
Other | | 0.3976 | | | 0.53
Nlocal: 250 ave 261 max 244 min
Histogram: 2 0 0 1 0 0 0 0 0 1
Nghost: 2008.75 ave 2029 max 1985 min
Histogram: 1 0 0 1 0 0 0 1 0 1
Neighs: 16485 ave 17202 max 16026 min
Histogram: 2 0 0 0 1 0 0 0 0 1
Total # of neighbors = 65940
Ave neighs/atom = 65.94
Neighbor list builds = 201
Dangerous builds = 0
Setting up Verlet run …
Unit style : lj
Current step : 1000
Time step : 0.005
Per MPI rank memory allocation (min/avg/max) = 7.055 | 7.055 | 7.055 Mbytes
Step Temp c_rot E_pair TotEng Press
1000 1.44 0.71963982 57.545011 59.702851 155.89971
ERROR: Lost atoms: original 1000 current 7 (../thermo.cpp:481)
Last command: run 1000
Regards,
Jenis
