Dear Lammps Users,
I was running a simulation of ice/Ih phase with a reaxff potential file.
When I ran the simulation first, my simulation crashed giving this error message:
step15585-hbondchk failed: H=275 end(H)=1071037260 str(H+1)=24697
So, I thought may be it is happening because hbond cut off (which was completely wrong assumption, I think). Hence, I increased the hbond cutoff in the control file and ran again. To my surprise, the system runs fine.
The way I understand this error is, since the number of H bonds were more than the designated allowable H bond lammps reax/c implementation allows, the program crashed due to its inability to allocate memory. That is why a remedy to this problem is increasing safezone and min cap.
But I do not understand why my simulation is running now. If earlier a lower value of hbond cutoff was crashed the program. A higher value of hbond cutoff should intensify the problem, but the opposite happened, and I am not able to understand why this happened.
Can someone, please explain what is going on here?
Ankit
