Hi Lammps users,
I have set up a system with dreiding force field, I need to verify following statement.
pair_coeff 3 4 hbond/dreiding/lj 5 j 9.0 2.75 4
where Atom type 3 is acceptor, 4 is donor, 5 is hydrogen atom,
In manual page, its given as K = hydrogen atom type = 1 to Ntypes
whether K value specified by me is correct?
Thanks in advance
Karteek Kumar
Hi Lammps users,
statement.
For one thing, in your pair_coeff statement is incomplete.
You need to specify 3 more numbers:
distance cutoff Rin (distance units)
distance cutoff Rout (distance units)
angle cutoff (degrees)
K should be the atom type number which corresponds to your hydrogen atom.
--- "i" or "j" ? ---
According to the documentation pate, if 4 is the donor, then the "j"
(in "5 j") is correct. (At least that's the way I understand it. If
you are worried this is not the case, then edit the
"pair_hbond_dreiding_lj.cpp" file, and add some printf statements in
the compute() function which print out the type of the hydrogen atom.
I can't give you more explicit instructions because I don't have
stable computer access right now.)
As always, let us know if you find a bug.
Andrew
Thanks Andrew for the reply,
In documentation, I was confused with below statement.
" If the donor flag is i, then the atom of type I in the pair_coeff command is treated as the donor, and J is the acceptor. If the donor flag is j, then the atom of type J in the pair_coeff command is treated as the donor and I is the donor"
In the above line, donor flag is j, both I & J are specified as donor.
Second thing, I didnt specified distance and angle cutoff in pair_coeff to use same as global cut off.
Now, I am unable to equilibrate a system with hbond/dreiding/lj. Total energy drifts continuously.
Please find some test files as attached.
Thanks in advance,
Karteek Kumar
test.tar (50 KB)
Hi Andrew,
I tried to equilibrate methanol system given in examples directory. Even that didnt helped me.
I tried with same files in NVE ensemble, total energy drifts ( not sure why?)
Again with NVT ensemble,
fix 2 all nvt temp 300.0 300.0 100.0
fix 2 energy yes
Total energy drifts again.
But surprisingly, If I comment out fix_modify energy yes, Total energy remains constant.
Please can you look into these things.
Karteek Kumar
