Greetings,
I am trying to run a simulation in which there are two solute molecules (modelled with reax/c), surrounded by solvent (modelled with OPLS). The simulation seems to work fine until about 1000-4000 iterations in (the exact number depends mostly on the time step), when LAMMPS crashes, producing the “hbondchk failed” error below. There seems to be nothing unusual in the dumped data prior to the error as far as I can see.
I’ve tried changing the safezone and mincap parameters, but this seems to have no effect
I’ve read that hbondchk errors can often be avoided by increasing skin distance; however, at best, this only seems to delay the crash
If I delete all the OPLS molecules (using delete_atoms), the error does not occur (at least, not within the number of iterations I’ve tried).
I have tried running this with both the latest stable version of LAMMPS (9/Dec/2014), and the 30/Jan/2015 version. The input file and data file are attached, and the output is below.
Might anyone be able to provide insight on what’s causing this and how to fix it?
The output:
LAMMPS (30 Jan 2015)
Reading data file …
orthogonal box = (10.3911 10.3911 10.3911) to (49.6089 49.6089 49.6089)
reading atoms …
126 atoms
scanning bonds …
4 = max bonds/atom
scanning angles …
6 = max angles/atom
scanning dihedrals …
12 = max dihedrals/atom
reading bonds …
70 bonds
reading angles …
124 angles
reading dihedrals …
144 dihedrals
Finding 1-2 1-3 1-4 neighbors …
4 = max # of 1-2 neighbors
7 = max # of 1-3 neighbors
14 = max # of 1-4 neighbors
16 = max # of special neighbors
56 atoms in group solute
WARNING: Using a manybody potential with bonds/angles/dihedrals and special_bond exclusions (…/pair.cpp:203)
Setting up run …
WARNING: Inconsistent image flags (…/domain.cpp:678)
Memory usage per processor = 20.5791 Mbytes
Step Temp PotEng TotEng Press Volume
0 363.15 -7024.806 -6889.4959 2674.505 60318
1 457.68833 -7065.7631 -6895.2279 2058.7727 60320.341
2 598.97361 -7123.8869 -6900.7085 1356.2881 60326.287
3 670.10842 -7146.2079 -6896.5247 1085.7373 60334.609
4 684.86777 -7153.1893 -6898.0067 782.01691 60344.835
5 672.92561 -7150.6515 -6899.9186 412.67248 60356.434
6 663.20755 -7146.3697 -6899.2578 410.78304 60368.76
7 667.55298 -7149.8988 -6901.1677 181.74156 60381.81
8 661.37186 -7148.1346 -6901.7066 -196.42309 60395.183
995 341.10028 -7278.7208 -7151.6264 256.41472 71430.528
996 357.86048 -7283.4336 -7150.0943 278.39294 71445.162
997 375.27844 -7290.1988 -7150.3696 67.43826 71460.471
998 376.89536 -7292.5313 -7152.0996 87.085242 71475.937
999 370.38435 -7289.9491 -7151.9434 57.758139 71491.608
1000 366.43567 -7288.5226 -7151.9882 -40.082169 71507.412
step1000-hbondchk failed: H=3 end(H)=130 str(H+1)=100
application called MPI_Abort(MPI_COMM_WORLD, -14) - process 0
ffield.reax (16.7 KB)
loop.data (11.2 KB)
loop.in (5.57 KB)
