I would expect the heating of an elastic material upon sudden elastic compression using such commands as change_box, fix box/relax or fix deform to be given simply by the first law of thermodynamics, i.e. Delta Q=Delta U + P Delta V where P is constant since the compression is applied suddenly as in a square-wave pressure pulse (this is equivalent to the change in enthalpy). This heat released by the material upon elastic compression should then be re-absorbed entirely by the material assuming periodic boundary conditions, and this is what gives rise to the rise in temperature of the material after the compression. If I'm not wrong then this heat released is basically converted entirely into thermal vibrational energy upon re-absorption (3NkbT in the classical limit). I tried calculating the thermal energy of iron for example from static zero-temperature energy surface calculations and phonon vibrational calculations, however my predictions for the rise in temperature upon elastic compression from these static calculations according to the above reasoning is much higher than the one I observe in the actual dynamic simulations. Can you see anything wrong with my reasoning? I've attached an example of input file showing the various compression commands that I've tried ( change_box, fix box/relax or fix deform).
Many thanks,
Gabriele Mogni
log log.deform
atom_style atomic
pair_style eam/alloy
atom_modify map array
lattice bcc 2.8665
region box block 0 20 0 20 0 20
create_box 1 box
create_atoms 1 box
mass * 55.847
pair_coeff * * Fe_Ack.eam Fe
compute red_temp all temp/partial 1 1 0
velocity all create 0 5812775
thermo 1000
thermo_style custom step temp vol lx ly lz press pxx pyy pzz etotal pe
thermo_modify norm yes lost warn flush yes
fix 1 all nve
timestep 0.001
run 0
#fix 2 all box/relax iso 339000
#minimize 1.0e-15 1.0e-15 100000 1000000
#fix 2 all deform 1 x final 0.0 55.345386 y final 0.0 55.345386 z final 0.0 55.345386 units box
change_box all x final 0.0 55.345386 y final 0.0 55.345386 z final 0.0 55.345386 remap units box
#run 1
#fix 2 all npt temp 300 300 0.10 iso 339000.0 339000.0 1.0
run 100000
