hello everyone
when I used fix ave/atom, I meet a problem with mpi.
in my input file:
fix 5 all ave/atom 1 5000 50000 x y z
dump 2 all custom 50000 dump.avepz id type f_5[1] f_5[2] f_5[3]
when I use mpich2-1.3.2p1: mpiexec -n 8 ./lmp_linux <myinput
ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
when I use openmpi 1.4: mpirun -np 8 ./lmp_openmpi <myinput
mpirun noticed that process rank 7 with PID 26565 on node matlab exited on signal 11 (Segmentation fault).
but: ./lmp_linux <myinput and ./lmp_openmpi<myinput
everything is OK.
if I dont use: fix 5 all ave/atom 1 5000 50000 x y z
both above are OK.
I try openmpi1.4 with intel compiler 11 and icc with mpich2-1.3.2p1, the problem are same.
in my .bashrc I also use: ulimit -s unlimited
fix ave/atom can not use with mpi? so please help me! thank you
2011/3/21 levi-levilw <[email protected]...>:
hello everyone
in my input file:
f_5[3]
everything is OK.
both above are OK.
there is not need to post the same question twice
to the list from different accounts even.
keep in mind that people live in different time zones
and that sometimes mailing list servers have delays
in their processing due to load.
cheers,
hello everyone
in my input file:
f_5[3]
everything is OK.
both above are OK.
cheers,
