Hi all,
I am a beginner and I would like to simulate an organic molecular crystal (like a Naphthalene organic crystal).
Could you please give me some suggestions about the most suitable force fields? I know that one should first look the literature, but I was not able to find anything useful.
Also, I have the coordinates of the atoms in the unit cell: would you suggest me to input the coordinates in lammps by the lattice command or via the read_data?
Finally: would you be able to provide a sample input file for a similar structure?
Thank you in advance for your help,
Carlo
Hi all,
I guess you didn't look very much. The OPLS-aa FF has been used for this
molecule (at least for liquid phase simulations)
See for example this link:
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CDwQFjAC&url=http%3A%2F%2Fdigitalcommons.uri.edu%2Fcgi%2Fviewcontent.cgi%3Farticle%3D1005%26context%3Dche_facpubs&ei=EaacUpuhKsaXqQHDt4CwDg&usg=AFQjCNGyOcAyG-ftuKjwpcR9vaDJvCBjVw&sig2=hCpb8jKfqvm9qkY7FNqziQ&bvm=bv.57155469,d.aWM&cad=rja
Now, I don't know if this FF can handle properly the crystalline phase of
your system. Maybe it will as this is a crystal where the structure is set
only by the VDW forces. However, you have to search the publication
repositories to find more about it.
the read_data?
What does it matter to your overall nutrition if your spoon is metallic or
plastic? Pick the method that is the easiest for you.
structure?
You can build it using your favorite molecular builder software: avogadro
(free), molden (free), material studio ($), and so on... There is a slim
chance a user here will have it ready for you.
Carlos
Hi Carlos,
thank you for your answer.
So if I correctly understand, what you suggest is to check the repository (http://lammps.sandia.gov/papers.html) anf look for similar systems?
Thank you for the paper you suggested. I think that, in order to use that FF, one has to set:
pair_style lj/cut/coul/long 10.5
bond_style harmonic
angle_style harmonic
dihedral_style opls
Sorry for my very naive questions but I come from the ab-initio side and I have really no confidence with MD.
My problems with the geometry input file is that I have not very clear how to set all the Pair Coeffs, Bond Coeffs, Angle Coeffs, Dihedral Coeffs, and all the numbers related to atoms, bonds, dihedrals, etc...
Regarding the coefficients, I have really no idea how to set them. For the numbers related to atoms, bonds, dihedrals... is there a cheap way to set them/
Thank you again,
Carlo
Ciao Carlo (I’m never sure if with the Italians that ciao is at the entrance or the exit like its is in Spanish),
