Hi all,
I am using LAMMPS Jan-2011 version for my work.
After some early lags, i started using LAMMPS successfully.
But now,i found a the following message at the end of my simulation.
However, the simulations has run perfectly without any problem.
Could you let me know what does these messages represent.
Will it affect the simulation running properly
[nansrc1:28247] *** Process received signal ***
[nansrc1:28248] *** Process received signal ***
[nansrc1:28249] *** Process received signal ***
[nansrc1:28250] *** Process received signal ***
[nansrc1:28250] Signal: Segmentation fault (11)
[nansrc1:28250] Signal code: Address not mapped (1)
[nansrc1:28250] Failing at address: (nil)
[nansrc1:28247] Signal: Segmentation fault (11)
[nansrc1:28247] Signal code: Address not mapped (1)
[nansrc1:28247] Failing at address: (nil)
[nansrc1:28248] Signal: Segmentation fault (11)
[nansrc1:28248] Signal code: Address not mapped (1)
[nansrc1:28248] Failing at address: (nil)
[nansrc1:28249] Signal: Segmentation fault (11)
[nansrc1:28249] Signal code: Address not mapped (1)
[nansrc1:28249] Failing at address: (nil)
[nansrc1:28250] [ 0] /lib64/libpthread.so.0 [0x3e2aa0eb10]
[nansrc1:28250] [ 1] lmp_linux(_ZN9LAMMPS_NS6Output14create_restartEiPPc+0x128) [0x59f004]
[nansrc1:28250] [ 2] lmp_linux(_ZN9LAMMPS_NS5Input7restartEv+0x1d) [0x56d2b1]
[nansrc1:28250] [ 3] lmp_linux(_ZN9LAMMPS_NS5Input15execute_commandEv+0x905) [0x56fae7]
[nansrc1:28250] [ 4] lmp_linux(_ZN9LAMMPS_NS5Input4fileEv+0x2b6) [0x570c1e]
[nansrc1:28250] [ 5] lmp_linux(main+0x5f) [0x578b9b]
[nansrc1:28250] [ 6] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3e29e1d994]
[nansrc1:28250] [ 7] lmp_linux(__gxx_personality_v0+0x119) [0x45cf89]
[nansrc1:28250] *** End of error message ***
[nansrc1:28248] [ 0] /lib64/libpthread.so.0 [0x3e2aa0eb10]
[nansrc1:28248] [ 1] lmp_linux(_ZN9LAMMPS_NS6Output14create_restartEiPPc+0x128) [0x59f004]
[nansrc1:28248] [ 2] lmp_linux(_ZN9LAMMPS_NS5Input7restartEv+0x1d) [0x56d2b1]
[nansrc1:28248] [ 3] lmp_linux(_ZN9LAMMPS_NS5Input15execute_commandEv+0x905) [0x56fae7]
[nansrc1:28248] [ 4] lmp_linux(_ZN9LAMMPS_NS5Input4fileEv+0x2b6) [0x570c1e]
[nansrc1:28248] [ 5] lmp_linux(main+0x5f) [0x578b9b]
[nansrc1:28248] [ 6] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3e29e1d994]
[nansrc1:28248] [ 7] lmp_linux(__gxx_personality_v0+0x119) [0x45cf89]
[nansrc1:28248] *** End of error message ***
[nansrc1:28247] [ 0] /lib64/libpthread.so.0 [0x3e2aa0eb10]
[nansrc1:28247] [ 1] lmp_linux(_ZN9LAMMPS_NS6Output14create_restartEiPPc+0x128) [0x59f004]
[nansrc1:28247] [ 2] lmp_linux(_ZN9LAMMPS_NS5Input7restartEv+0x1d) [0x56d2b1]
[nansrc1:28247] [ 3] lmp_linux(_ZN9LAMMPS_NS5Input15execute_commandEv+0x905) [0x56fae7]
[nansrc1:28247] [ 4] lmp_linux(_ZN9LAMMPS_NS5Input4fileEv+0x2b6) [0x570c1e]
[nansrc1:28247] [ 5] lmp_linux(main+0x5f) [0x578b9b]
[nansrc1:28247] [ 6] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3e29e1d994]
[nansrc1:28247] [ 7] lmp_linux(__gxx_personality_v0+0x119) [0x45cf89]
[nansrc1:28247] *** End of error message ***
[nansrc1:28249] [ 0] /lib64/libpthread.so.0 [0x3e2aa0eb10]
[nansrc1:28249] [ 1] lmp_linux(_ZN9LAMMPS_NS6Output14create_restartEiPPc+0x128) [0x59f004]
[nansrc1:28249] [ 2] lmp_linux(_ZN9LAMMPS_NS5Input7restartEv+0x1d) [0x56d2b1]
[nansrc1:28249] [ 3] lmp_linux(_ZN9LAMMPS_NS5Input15execute_commandEv+0x905) [0x56fae7]
[nansrc1:28249] [ 4] lmp_linux(_ZN9LAMMPS_NS5Input4fileEv+0x2b6) [0x570c1e]
[nansrc1:28249] [ 5] lmp_linux(main+0x5f) [0x578b9b]
[nansrc1:28249] [ 6] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3e29e1d994]
[nansrc1:28249] [ 7] lmp_linux(__gxx_personality_v0+0x119) [0x45cf89]
[nansrc1:28249] *** End of error message ***
Thanks in advance
Sincerely,
Naresh
