Dear All,
I am running some simulations that require applying a relatively high electric field pulse (~10ps) to a solid material.
The magnitude of the electric filed is normally around 1MV/cm to 4MV/cm (0.01eV/A - 0.04eV/A).
I use “fix NPT” to control the temperature. Using the “metal” unit, I set the Tdamp to be 1.0 (that is 1.0ps) and use a time step of 1fs (sometimes 0.5fs).
I think my Tdamp is reasonable.
I notice that if the electric field is high, for example, 2.0 MV/cm, the temperature will shoot up for about ~50K.
In practice, we can tune Tdamp (e.g., Tdamp=0.05) so as to maintain the temperature during the application of electric field. But, I am not sure whether that is a physically correct way to do:
By applying the electric field, the system is gaining energy. Assuming that the rate of energy exchange between the system and the environment (thermostat) is constant, the temperature of the system should rise up.
The situation now is Tdamp will influence the kinetics of my system. (Tdamp=1.0 will give very different result when Tdamp = 0.05).
I am eager to know your suggestions or comments.
Sincerely,
Shi
