I am trying to obtain thermodynamic properties of liquid propellant mixtures such as N2H4 + H2O2. My codes ran without errors, but the results showed properties with high fluctuations, inconsistent with the experimental data. I am simulating in the NPT ensemble, with OPLS- All Atom, in the temperature range of 250 to 500 K and constant pressure of 10 atm. What I’ve already tried:
I doubled the number of molecules from 500 to 1000.
I increased the equilibration time to 2000000.
The fluctuations are still high, I am calculating the thermal capacity, the coefficient of thermal expansion, the isothermal compressibility, the Joule-Thomson coefficient, and the Speed of Sound.
Could anyone tell me what could be causing this problem?
My input:
#N2H4_H2O2_NPT
units real
atom_style full
variable T equal 250 # [K]
variable P equal 10 # [atm]
variable sigma equal 3.368 # [Å]
variable rc equal 2.5*${sigma} # [Å]
pair_style lj/cut/coul/long ${rc}
pair_modify mix arithmetic tail yes
bond_style harmonic
angle_style harmonic
dihedral_style harmonic
#kspace_style pppm 1.0e-4
kspace_style ewald 1.0e-4
read_data N2H4_H2O2_50.lmp_data
velocity all create $T 261086 rot yes dist gaussian
timestep 1.0
fix NVE all nve
run 1000
unfix NVE
fix NPT all npt temp $T $T 100.0 iso $P $P 1000.0
run 2000000
reset_timestep 0
variable dens equal density*1000 # [kg/m³]
thermo_style custom step temp press vol v_dens pe ke etotal etail
thermo 300
dump dump all custom 100 N2H4_H2O2_NPT.dump element id x y z
#dump_modify dump element N H H O sort id
run 1000000
The beginning of N2H4_H2O2_50.lmp_data :
LAMMPS data file
4 atom types
4 bond types
3 angle types
4 dihedral types
5000 atoms
4000 bonds
4000 angles
6500 dihedrals
-20.5239716 20.5239716 xlo xhi
-20.5239716 20.5239716 ylo yhi
-20.5239716 20.5239716 zlo zhi
Masses
1 1.00784 # HIW
2 15.999 # OW
3 14.0067 # NW
4 1.00784 # HW
Pair Coeffs
1 0.054 2.332 # HIW
2 0.012 2.100 # OW
3 0.7113 3.3368 # NW
4 0.0000 0.000 # HW
Bond Coeffs
1 535 1.475 # OW OW
2 553 0.950 # OW HIW
3 360.00 1.402 # NW NW
4 445.00 1.045 # NW HW
Angle Coeffs
1 35 94.8 # HIW OW OW
2 43.600 107.0 # HW NW HW
3 271.96 108.0 # NW NW HW
Dihedral Coeffs
1 4 1 3 # HIW OW OW HIW
2 0.3920 1 3 # HW NW NW HW
3 0.3920 1 3 # HW NW NW HW
4 0.3920 1 3 # HW NW NW HW
Atoms
1 1 2 -0.312 17.7830944 14.8480721 11.3975306 # O1
2 1 2 -0.312 18.1244774 13.6185637 11.0717010 # O2
3 1 1 0.312 18.6429005 15.3300190 11.5039358 # HI1
4 1 1 0.312 17.9972916 13.5720959 10.0895948 # HI2
