Respected peers,
I am trying to simulate the lignin molecule with a mixture of ozone and water with reaxff potential (I used the reaxff potential available on the LAMMPS example.). I am getting some questionable values for pressure. While running for NVE simulation on the following system: lignin + 500 ozone + 3500 water for 1 ns and 0K starting temperature, the system recorded a very high negative pressure of negative tens of thousand. Later this value saturated to around -2000 as the simulation reaches the end of 1 ns (the temperature at the end of 1 ns is around 473 K). According to LAMMPS documentation, the pressure is supposed to be atm units (I used ‘real’ units). Considering the negative pressure, I incremented water molecules to 5000 but the pressure trend remained the same (I simulated this particular system for 10 ns). I am pretty new with LAMMPS and I will be grateful if someone will help me understand these results
Below is my input file (for lignin + 500 ozone + 3500 water system).
units real
atom_style charge
read_data data.lignin+ozone+water.charge
pair_style reaxff lmp_control
pair_coeff * * ffield.reax.cho C H O
group lig id 1:201
group ozn id 202:1701
group water id >= 1702
group lig+ozn id 1:1701
compute reax all pair reaxff
#compute pressure all pressure thermo_temp
variable eb equal c_reax[1]
variable ea equal c_reax[2]
variable elp equal c_reax[3]
variable emol equal c_reax[4]
variable ev equal c_reax[5]
variable epen equal c_reax[6]
variable ecoa equal c_reax[7]
variable ehb equal c_reax[8]
variable et equal c_reax[9]
variable eco equal c_reax[10]
variable ew equal c_reax[11]
variable ep equal c_reax[12]
variable efi equal c_reax[13]
variable eqeq equal c_reax[14]
thermo 1
neighbor 2.5 bin
neigh_modify every 10 delay 0 check yes
#velocity all create 300.0 4928459 mom yes rot yes dist gaussian
#fix 1 all nve temp 300.0 300.0 0.1
fix 1 all nve
fix 2 all qeq/reaxff 1 0.0 10.0 1.0e-6 reaxff
fix 4 all reaxff/bonds 20 bonds.reaxff.lignin+ozone+water_nve300_1ns
fix 5 lig reaxff/bonds 20 bonds.reaxff.lignin+ozone+water(lignin)_nve300_1ns
fix 6 ozn reaxff/bonds 20 bonds.reaxff.lignin+ozone+water(ozone)_nve300_1ns
fix 7 lig+ozn reaxff/bonds 20 bonds.reaxff.lignin+ozone+water(lignin+ozone)_nve300_1ns
#fix 8 all press/berendsen iso 0.0 0.0 1000.0
#fix 5 all bond/break 5 1 1.9
minimize 1.0e-6 1.0e-9 10000 100000
log log.lignin+ozone+water.nve300_1ns
variable nqeq equal f_2
thermo_style custom step temp epair etotal press &
v_eb v_ea v_elp v_emol v_ev v_epen v_ecoa &
v_ehb v_et v_eco v_ew v_ep v_efi v_eqeq v_nqeq
timestep 0.1
dump 1 all atom 20 dump.reaxff.lignin+ozone+water_nve300_1ns
dump 2 lig atom 20 dump.reaxff.lignin+ozone+water(lig)_nve300_1ns
dump 3 ozn atom 20 dump.reaxff.lignin+ozone+water(ozn)_nve300_1ns
dump 4 lig+ozn atom 20 dump.reaxff.lignin+ozone+water(lig+ozn)_nve300_1ns
restart 10000 restart.lignin+ozone+water_nve300_1ns
run 10000
Please let me know if the above-mentioned information is enough to pinpoint the issue. My apologies as being a new user, I couldn’t upload my log file.
Thank you in advance.
