Dear Users,
I wrote a script to evaluate different temp. as shown below but the system was destroy, any one have idea about that
Cheers,
Alaa
set up units basic initial paramters
units real
atom_style charge
define and create simulation domain
region bbox block -100 100 -100 100 -100 100
create_box 4 bbox
place atoms in the box with(x,y,z)coordinates and type
create_atoms 1 single -1.43492000 -2.85265000 -72.84560000 units box
create_atoms 1 single 1.44508000 -2.85265000 -72.84560000 units box
create_atoms 1 single 4.32508000 -2.85265000 -72.84560000 units box
create_atoms 1 single 2.88000000 1.65500000 63.49200000 units box
#set the mass of each atom types
mass 1 196.9665
mass 2 12.00
mass 3 1.00
mass 4 32.066
#define groups of atoms
group left id <> 1 243
group right id <> 258 500
group junction id <> 244 257
define forcefield between atoms (reaxff is easy)
pair_style reax/c NULL checkqeq no
pair_coeff * * ffield_C_H_O_S_Au.reax Au C H S
setup the simulation
initiall temperature
velocity all create 600.0 4976559 rot yes dist gaussian ##4928459
fix 1 all nvt temp 300.01 300.01 100.0
velocity right create 100.0 47459 rot yes dist gaussian ##44592
fix 2 right nvt temp 100.01 100.01 100.0
velocity junction create 225.0 49753 rot yes dist gaussian ##4928459
fix 3 junction nve
relaxing (optimizing) the geometry (not mandatory) (this will run immediately)l
fix UCBOX all box/relax iso 0.0 vmax 0.001
minimize 0.0 1.0e-8 1000 10000
unfix UCBOX
there is a good default, no need it
timestep 0.5
#run 5000
#unfix 1
#fix 1 all nve
compute ke all ke/atom
variable temp atom c_ke/(1.5*0.0019872041)
fix 8 all ave/spatial 2 10000 30000 z lower 6.8 v_temp file tmp.profile units box
fix 9 all thermal/conductivity 600 z 6 swap 1
reset_timestep 100
writes out the thermodynamical variables (temperature, pressure, totlaenergy, each 100 timesteps)
thermo_style custom step time temp ke pe etotal press vol f_9
thermo 600
LAMMPS - DUMP OUT THE INITIAL GEOMETRY
dump 1 all xyz 1 optimized.xyz
run 0
undump 1
LAMMPS - DUMP OUT THE TIME EVOL GEOMETRY
dump 1 all xyz 10000 timeevol.xyz
dump d0 all cfg 100 *.cfg mass type xs ys zs vx vy vz fx fy fz
#dump i all image 200 dump.*.jpg type type
run 100000
unfix 2
fix 4 right nve
run 100000
unfix 1
#fix 5 left nve
#run 1000000
