I want to calculate MSD of some atoms in a group with same atom type. For example, I have tree types of atoms like, nitrogen, carbon, oxygen. Now after equilibration, I calculate the RDF and found that the first neighbor distance from nitrogen to carbon 0.31nm and from oxygen 0.37nm. Since, all ate in a mixture, I want to calculate the carbons those have 0.31nm distance from nitrogen. Therefore, I thinking If I can, find the index of those carbons then I can make a group and calculate the MSD.
It will be very helpful if someone help how can I do it in LAMMPS
It does not do exactly what you want, but perhaps it points you in a
good direction.
More generally, you could write your own code to compute the RDFs you need.
The DUMP files created by the LAMMPS' dump command have a simple,
easy-to-parse syntax.
Usually you can write a short program which can read an ordinary DUMP
file (trajectory file) created by LAMMPS, and calculate the quantities
you are interested in. The best way to learn the file format is to
create a DUMP file using the LAMMPS' dump command: http://lammps.sandia.gov/doc/dump.html
this may be possible using compute coord/atom. please check out the
documentation.
