How can I equilibrate the model with constant pressure?
Sorry for my repeatative query.
A few days ago, I asked a question about bidirectional motions of water molecules inside CNT. Andrew did favor and explain that it might come from that the model (A reservoir+CNT) did not reach equiulbration with constant pressure. He suggested me an example that I tested it but it does not work for my model.
I am using NVE ensemble in conjection with DPD thermostat to keep constant temperature. I applied an external force on water molecules with “fix addforce ” command only in Z direction (pore axis). After simulation I see that water molecules enter the pore from both ends (The attached) instead of having an unidirectional motion. Actually, I would like to have an unidirectional motion.
I have searched about that through mailing list but I could not find much information. Actually, I could catch it that to apply a costant pressure by using a piston on water molecules the “fix aveforce ” command might be used . But for my case I could not be succeeded. I tried using “fix NPT” instead of NVE , but the volume (simulation box) is changed.
Could you please let me know how I can do that?
Thanks in advance
Screenshot from 2015-07-25 14:41:17.png
for my model.
​design a better model. you are using periodic boundaries, right?
so, as has been explained (in great detail, as usual) by andrew, it is
quite expected that on the atomic scale atoms will move into the CNT. you
cannot really expect macroscopic behavior. also, the water molecules
entering will be mostly doing this for simple entropic and energetic
reasons and much less so due to the force that you are adding. that all can
be very easily rationalized.
if you don't want water to not enter from the other side, don't put water
there, i.e. don't use PBC, place a barrier (e.g. via fix oneway) that
pushes water back. regardless, overall, what you are complaining about
seems to be an intrinsic property of your setup and you'd rather have to
review your model design. if you want to force the molecules the way you
expect them to behave, you are not longer doing science, but rather will be
doing an animation, i.e. you are preparing for a job at pixar rather than
aiming to become a nobel laureate.
Dear Axel,
Thank you very much for the quick reply. Yes, you right. I am using PBC. Let’s do your advices.
Thanks in advance
pressure.
I just mentioned in passing that it would be a good idea to equilibrate the liquid under constant pressure before you simulate water flowing through the nanotube.
But, to be clear, this is not the reason you have water entering the nanotube.
That would happen anyway.
for my model.
In my previous email I was trying to convey that I don’t think unidirectional motion would be realistic. The water is going to enter the tube from both sides (assuming there is water present on both sides) because of surface tension.
However after this occurs, I would expect that if you continue to apply force to the water molecules (either using fix addforce or fix wall/piston, or something similar, then water would eventually flow from one side of the tube to the other side. (See below)
If you keep running the simulation for a longer period of time, I suspect you will eventually see water molecules slowly traveling from one side of the tube to the other. You can attempt a very crude (order of magnitude) estimate the rate at which the water molecules should be flowing using:
https://en.wikipedia.org/wiki/Hagen%E2%80%93Poiseuille_equation
…And I suspect that the water would flow through the tube at a rate much slower than the rate at which it entered the tube initially.
That is what is supposed to happen…
(Even so, it is not always easy to get it to converge to the correct volume.)
Eventually, if you plan to publish this work, you will need to choose a realistic box size for the number of water molecules in your system. Running an NPT simulation is how you can do do that. However if you are doing this a class assignment and you need a quick result, then perhaps you can get away with estimating the box size by calculating the total volume available to the water in the box and in the tube, and knowing the density of real bulk water. In any case, I would start with that, and worry about pressure equilibration later. (Performing pressure-equilibration simulations in the presence of a large rigid obstacle is not trivial. I suggest you get the other aspects of your simulation working before tackling this issue.)
Andrew
Dear Andrew,
Sorry for my misunderstanding.
Thank you so much to making me clear through your previous and current replies. As Axel and you commented an unidirectional would not be realistic. So, I will try it on running for a longer simulation time (I have already done it for more than 2ns that was not enough ). It might be unidirectional after longer time, as you commented.
Let me highly appreciate Axel and you for your valuable time.
Thanks in advance
