I attempted to search for all the structures of type ABC3, but found that it was not comprehensive.Because there are some perovskite compounds whose chemical formulas cannot be simply summarized as ABC₃. Such as Cs3Sb2I9.
Hey @Chuanxi-cairen, there are a couple options: if you have a list of anonoymized formulae (ABC3, A3B2C9, etc.) you can query directly for those.
Otherwise, you can search by crystal prototype using the robocrystallographer documents and manually-assigned provenance:
with MPRester() as mpr:
robocrys_docs = mpr.materials.robocrys.search(
keywords=["perovskite"]
prov_docs = mpr.materials.provenance.search(
fields=["material_id","remarks","tags"]
robo_perov_mpids = [doc.material_id for doc in robocrys_docs]
possible_perov = [
doc.material_id for doc in prov_docs
if any("perovskite" in tag.lower()
for tag in (doc.tags+doc.remarks))
likely_perovskite_mpids = list(
set(robo_perov_mpids).union(possible_perov)
Thanks!I extracted 4266 likely materials project id of perovskite. When I ran this code, I found that
possible_perov = [
should be changed to
possible_perov = [
doc.get("material_id") for doc in prov_docs
for tag in (doc.get("tags", []) + doc.get("remarks", [])))
as prov_docs is a dictionary.
prov_docs
should be a list of dictionaries if you use MPRester(use_document_model=False)
, but the default behavior should give you python objects (the pydantic document models)
I did use “use_document_model=False”. Thank you very much for clearing up my confusion.
