I would like to print the elapsed (CPU) time every few steps.
The run command is executed repeatedly inside a loop, so I tried to define a variable (runTime) to store the elapsed time.
However, I noticed that the LAMMPS thermo keyword cpu seems to reset each time the run command is invoked.
#Test
units si
atom_style sphere
comm_modify vel yes
region r1 block -10 10 -10 10 -10 10
create_box 1 r1
timestep 1E-3
region r2 block -5 5 -5 5 0 5
create_atoms 1 random 10 12123123 r2
pair_style gran/hertz/history 1E8 1E5 1000 100 0.5 1
pair_coeff * *
fix f1 all nve/sphere
variable nStep equal step
variable runTime equal 0
variable RrunTime equal ${runTime}+cpu
#variable start timer
label l1
variable indexP loop 5
fix f2 all print 20000000 "index ${indexP} step ${nStep} runTime $(v_RrunTime:%8.5f)"
run 100000000
next indexP # Next step for Pouring
jump SELF l1
#variable stop timer
I am confused by the resulting output:
the runTime variable appears to reset in every run, yet there is an unexpected line printed before starting the next loop iteration.
That line repeats the final step of the previous loop and shows an accumulated elapsed time after the third loop.
Could someone please explain how to consistently print the correct elapsed time in each run?
=== 1st loop ===
Setting up Verlet run ...
Unit style : si
Current step : 0
Time step : 0.001
index 1 step 0 runTime 0.00000
Per MPI rank memory allocation (min/avg/max) = 10.31 | 10.31 | 10.31 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0 0 0 0 0
index 1 step 20000000 runTime 8.45127
index 1 step 40000000 runTime 16.75214
index 1 step 60000000 runTime 25.05487
index 1 step 80000000 runTime 33.35907
index 1 step 100000000 runTime 41.66397
100000000 0 0 0 0 0
Loop time of 41.664 on 1 procs for 100000000 steps with 10 atoms
100.0% CPU use with 1 MPI tasks x 1 OpenMP threads
=== 2dn loop ===
Unit style : si
Current step : 100000000
Time step : 0.001
index 2 step 100000000 runTime 0.01740
100000000 0 0 0 0 0
index 2 step 120000000 runTime 8.29881
index 2 step 140000000 runTime 16.60269
index 2 step 160000000 runTime 24.90508
index 2 step 180000000 runTime 33.20836
index 2 step 200000000 runTime 41.51192
200000000 0 0 0 0 0
Loop time of 41.512 on 1 procs for 100000000 steps with 10 atoms
=== 3rd loop ===
Unit style : si
Current step : 200000000
Time step : 0.001
index 3 step 200000000 runTime 41.68179
200000000 0 0 0 0 0
index 3 step 220000000 runTime 8.30832
index 3 step 240000000 runTime 16.61235
index 3 step 260000000 runTime 24.92323
index 3 step 280000000 runTime 33.22722
index 3 step 300000000 runTime 41.53040
300000000 0 0 0 0 0
Loop time of 41.5304 on 1 procs for 100000000 steps with 10 atoms
=== 4th loop ===
Unit style : si
Current step : 300000000
Time step : 0.001
index 4 step 300000000 runTime 83.19410
300000000 0 0 0 0 0
index 4 step 320000000 runTime 8.30554
index 4 step 340000000 runTime 16.61124
index 4 step 360000000 runTime 24.91832
index 4 step 380000000 runTime 33.22760
index 4 step 400000000 runTime 41.53892
400000000 0 0 0 0 0
Loop time of 41.539 on 1 procs for 100000000 steps with 10 atoms
=== 5th loop ===
Unit style : si
Current step : 400000000
Time step : 0.001
index 5 step 400000000 runTime 124.72491
400000000 0 0 0 0 0
index 5 step 420000000 runTime 8.31042
index 5 step 440000000 runTime 16.61925
index 5 step 460000000 runTime 24.92573
index 5 step 480000000 runTime 33.23294
index 5 step 500000000 runTime 41.54407
500000000 0 0 0 0 0
Loop time of 41.5441 on 1 procs for 100000000 steps with 10 atoms
