How does fix bond/react handle multiple possible reaction partners for the same atom?
When using fix bond/react in LAMMPS, consider a simple two-body reaction template. Suppose atom 1 simultaneously satisfies the reaction template with two different atoms (e.g., atom 2 and atom 3). How does the algorithm handle this situation?
For example, if both pairs (1,2) and (1,3) match the reaction template at the same timestep, does the code first attempt the reaction between atoms 1 and 2, and if that reaction is successful, skip any further checks involving atom 1 (such as the pair 1–3)? Or are multiple candidate reactions involving the same atom evaluated in some other way?
I encountered a segmentation fault while running my simulation and I am unsure whether it might be related to this situation, where one atom simultaneously matches multiple possible reaction partners.
[m4cl0802:11407:0:11407] Caught signal 11 (Segmentation fault: address not mapped to object at address 0xb8)
[m4cl0802:11408:0:11408] Caught signal 11 (Segmentation fault: address not mapped to object at address 0xb8)
==== backtrace (tid: 11407) ====
0 0x0000000000012d20 __funlockfile() :0
1 0x0000000000d0d4c4 LAMMPS_NS::LabelMap::infer_bondtype() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../label_map.cpp:386
2 0x0000000000eaf0bd LAMMPS_NS::FixBondReact::update_everything() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../fix_bond_react.cpp:3378
3 0x0000000000ebe132 LAMMPS_NS::FixBondReact::superimpose_algorithm() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../fix_bond_react.cpp:1507
4 0x0000000000ebe132 ???() /publicfs01/fs1-share/soft/share-soft/gcc/install-14.2.0/include/c++/14.2.0/bits/stl_vector.h:368
5 0x0000000000ebe132 ???() /publicfs01/fs1-share/soft/share-soft/gcc/install-14.2.0/include/c++/14.2.0/bits/stl_vector.h:738
6 0x0000000000ebe132 LAMMPS_NS::FixBondReact::superimpose_algorithm() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../fix_bond_react.cpp:1508
7 0x0000000000ebfba9 LAMMPS_NS::FixBondReact::post_integrate() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../fix_bond_react.cpp:1027
8 0x000000000079071f LAMMPS_NS::Modify::post_integrate() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../modify.cpp:413
9 0x0000000000615c64 LAMMPS_NS::Verlet::run() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../verlet.cpp:259
10 0x00000000008f20e0 LAMMPS_NS::Run::command() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../run.cpp:176
11 0x00000000005b8742 LAMMPS_NS::Input::execute_command() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../input.cpp:877
12 0x00000000005b940c LAMMPS_NS::Input::file() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../input.cpp:315
13 0x00000000004cd5bc main() /publicfs01/fs1-m8/home/m8s000154/software-m8s000154/lammps-11Feb2026/src/Obj_mpi/../main.cpp:66
14 0x000000000003a7e5 __libc_start_main() ???:0
15 0x00000000004cf83e _start() ???:0
the error solved but my question still exists
