How to add the constant C to LJ potential in LAMMPS as follows?
For the second line I have to use “pair_modify shift” but I am not sure how to add C.
Fernanda
Fernanda
For the second line I have to use "pair_modify shift" but I am not sure
how to add C.
it is computed automatically from your cutoff when you issue the
pair_modify shift command.
if you need a different value of C, you first need to explain what you want
to use that for.
Hi Axel,
I got it.
Thank you
Fernanda
