Thanks for you replying.I want to array a region.Then I will delete atoms in these array regions .So,what’s your advice for me.Thanks.
—Original—
—Original—
“to array a region” is not a meaningful expression in english, so i don’t understand what you are saying here.
i’ve given you two possible options. it is up to you to figure out which is applicable to your case and your needs.
