how to build lat.in file?
Dear sir,
I want to study a solid solution with orthorhombic structure,which has no symmetry, through the Cluster Expansion code,now hou do I build the lat.in file ? Should I just writ the lattice as its POSCAR (VASP),or choose one from the given structures,such as bcc,fcc,hcp ? Besides,I wonder is there any relationship between the structure in lat.in and the structures of ground states ? In other words,how to choose a structure as the input file befor we calculate the ground states through Cluster Expansion?
Can we use cluster expansion for interstitial solid solution? and interstitial compound?
These are very fundamental open-ended questions! You might want to look at standard alloy theory references:
title="Order and Phase Stability in Alloys",
author="F. Ducastelle",
publisher="Elsevier Science",
address="New York",
year="1991"
Here are some more ATAT-focused refs:
https://arxiv.org/abs/cond-mat/0201511
https://arxiv.org/abs/cond-mat/0212159
Let me try to answer some of the more specific questions:
  1. even though a solid solution has no symmetry, the lat.in would list all species that can occupy each site. The symmetry of lat.in is much higher: it would be as if you ignore the distinction between the species residing on the same sublattice.
  2. For interstitials, you can create a sublattice that holds either some species or vacancies (denoted Vac).
