Dear users,
I’m trying to calculate the pressure on the solid surface when the droplet hits the solid surface (from the vertical direction of the impact), the droplet is a simple spherical water droplet, the pt atoms arranged in seven layers are the solid base, part of the code is below, what is wrong in my setup?
Modeling…(ppf)
Relaxation…(NVT)
unfix nvt
fix 1 all nve
compute subTemp pt temp
compute 2 pt stress/atom subTemp
compute v pt Voronoi/atom
variable stressz atom c_2[3]/c_v[1]*100000 ##units Pa
dump pressure pt custom 40 pt.xyz id type x y z v_stressz
Then I put the file into OVITO and the visual pressure chart didn’t meet my expectations, and I wondered if there was something wrong with my code? At the same time, what do I need to set up to eliminate the pressure of the lower solid atoms on the surface atoms?
